Starting problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 11-16-2006, 09:58 AM Thread Starter
Starting problem
Hey ALL, I recently acquired a '96 model and went ahead and swapped out the battery with a MF, well afterwards I get nothing..dead in the water..
If for some reason I didn't get a full charge on her could this be the cause?
Any all suggestions appreciated. Oh and like a DA I trashed the old battery.
Quint is offline
post #2 of 12 (permalink) Old 11-16-2006, 10:36 AM
93VN750's Avatar
What is the battery voltage with no load?
What is battery voltage when you press starter button?
Is kill switch off ? (I've done it, most of us have)
In neutral on side stand?
Did it start, turn over, click with the old battery?
Lets start here.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 12 (permalink) Old 11-16-2006, 11:06 AM Thread Starter
Will check voltages this evening and get back. Kill switch was off, yes to neutral with sidestand and yes it did start with old battery after a quick charge...Thanx
Quint is offline
post #4 of 12 (permalink) Old 11-16-2006, 12:27 PM
Is there any power going to the bike when ya turn the key on. If not, ya might have blown a fuse.
Also, be sure that all the connections on the battery are clean & tight.
post #5 of 12 (permalink) Old 11-16-2006, 08:49 PM
Search Goddess
Dianna's Avatar
My guess is with installing the new battery you have a bad ground or loose connection. Make sure you check both ends of the battery cables too and the ground contact area is clean.
Checking the fuses may be a good place to start too since I do believe you can pop a fuse if you hooked the battery up wrong. If you had sparks, I'd check the junction box.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 12 (permalink) Old 11-25-2006, 09:45 PM Thread Starter
Turned out to be a faulty battery...Thanks for the replys...now need to check out the ticking noise.
Quint is offline
post #7 of 12 (permalink) Old 11-26-2006, 06:43 PM
Sky Rider's Avatar
Ticking usually = ACCTs.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #8 of 12 (permalink) Old 11-27-2006, 10:01 AM Thread Starter
Does this mean replace or maintenance?
Quint is offline
post #9 of 12 (permalink) Old 11-27-2006, 11:06 AM
check out the verses for grambo's trick...the springs may just be sticking. I'm going to assume that since the bike is a 96 the mileage is not too high, so my guess would be to try that and see if it goes away...if you decide to change the ACCT's check out the manual ones that are made...Dianna would be a perfect one to talk to about them.
TrashLord is offline
post #10 of 12 (permalink) Old 11-27-2006, 10:03 PM
Hi all,
i ve also bought a 96's model and i got 2 problem that needed help:
1. I rode bike till hot and turn off the engine after a short conversation or fill up the gas tank the engine just wont start i can hear it was trying to turn but i would normally turn key off and try several times before it roar to life.
2. When i ride my bike past 60mph it started to jerk a little before going up to 70mph or more, strange as lift it's lack of air or something.
Also i need a suggestion to mount saddle bags without the standard bracket which is a hassle that we need to remove the turn signal and helmet locks.
cheers
fike
fikebike is offline
