Torque values - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 05-07-2013, 10:33 AM Thread Starter
Torque values
Found this file posted at the yahoo forum when looking for info on a torque spec question. Might be worth making it a sticky somewhere:
Standard Torque table (* = this is a Standard Fastener Torque)
These dimensions are the sizes of the bolt/screw,
NOT the size of the tool to fit the nut/bolt head.
5 mm = 30- 34 in-lb* (> 3/16")
6 mm = 52- 69 in-lb* (< 1/4")
8 mm = 10- 13 ft-lb* (= 5/16")
10 mm = 19- 25 ft-lb* (< 7/16")
12 mm = 33- 45 ft-lb* (< 1/2")
14 mm = 54- 72 ft-lb* (< 9/16")
16 mm = 83-115 ft-lb* (> 5/8")
18 mm = 125-165 ft-lb* (< 3/4")
20 mm = 165-240 ft-lb* (< 13/16")
NOTE: to convert in-lb to ft-lb, divide by 12 (Ex: 60 in-lb = 5 ft-lb)
to convert ft-lb to in-lb, multiply by 12 (Ex: 8 ft-lb = 96 in-lb)
Most of these torque values are from the Clymer Service Manual
If you find errors or have values not listed, email "doowriter123", and I will update the file.
Tightening Torques
BRAKES:
Rear brake pedal pinch bolt . . . . 18 ft-lb
Disc bolts . . . . . . . . . . . . . 16.5 ft-lb
Front banjo bolts (ALL) . . . . . . 18 ft-lb
Front caliper bleed valve . . . . . 5.8 ft-lb
Front caliper mounting bolts . . . . 24 ft-lb
Rear brake arm bolt . . . . . . . . 13.5 ft-lb
CLUTCH / TRANSMISSION:
Clutch lock nut . . . . . . . . . . 96 ft-lb
Clutch spring (pressure plate) bolts 80 in-lb = 6.7 ft-lb
Damper cam nut . . . . . . . . . . . 89 ft-lb
COOLING SYSTEM:
Cylinder drain plugs . . . . . . . . 78 in-lb = 6.5 ft-lb
Radiator drain plug . . . . . . . . 26 in-lb = 2.2 ft-lb
Radiator mounting bolts . . . . . . 52-69 in-lb*
Thermostat housing bleed valve . . . 69 in-lb = 5.7 ft-lb
ELECTRICAL:
Rectifier/Regulator bolts . . . . . 60 in-lb = 5 ft-lb
Starter one-way clutch Allen bolts . 25 ft-lb
Stator mounting bolts . . . . . . . 52-69 in-lb*
Rotor mounting bolt . . . . . . . . 33-45 ft-lb*
ENGINE:
Balance bolts - left & right . . . . 51 ft-lb
Camshaft bearing cap bolts . . . . . 8.5 ft-lb
Chain guide bolts, upper . . . . . . 17.5 ft-lb
Chain guide tentioner bolts, upper . 11 ft-lb
Connecting rod cap nuts . . . . . . 34 ft-lb
Cylinder block nuts . . . . . . . . 18 ft-lb
Cylinder head cover bolts . . . . . 87 in-lb = 7.3 ft-lb
Cylinder head bolts . . . . . . . . 8.5 ft-lb
Cylinder head to crankcase stud nuts:
6mm preliminary . 61 in-lb = 5 ft-lb
6mm final . 11 ft-lb
10mm preliminary . 18 ft-lb
10mm final . 29 ft-lb
Cylinder head to cylinder nuts:
6mm preliminary . 78 in-lb = 6.5 ft-lb
8mm preliminary . 13 ft-lb
8mm final . 18 ft-lb
Engine coolant drain plugs . . . . . 78 in-lb = 6.5 ft-lb
Neutral switch . . . . . . . . . . . 19-25 ft-lb*
Oil drain plug - bottom . . . . . . 13 ft-lb
Oil screen/drain plug - side . . . . 13 ft-lb
Oil filter . . . . . . . . . . . . . 13 ft-lb
Oil line - external bolt . . . . . . 8.5 ft-lb
Oil pressure switch . . . . . . . . 11 ft-lb
Oil pressure switch bolt . . . . . . 14.5 ft-lb
Primary drive gear bolt . . . . . . 89 ft-lb
Reed valve cover bolts . . . . . . . 60 in-lb = 5 ft-lb
Shift lever pinch bolt . . . . . . . 60 in-lb = 5 ft-lb
Spark plugs . . . . . . . . . . . . 12 ft-lb
Spark plug retainer . . . . . . . . 8.5 ft-lb
EXHAUST:
Exhaust manifold cap nuts . . . . . 18 ft-lb
Muffler mount bolt & nut . . . . . . 11 ft-lb
FRAME:
Sub-frame front & rear bolts . . . . 33 ft-lb
Frame front cross-brace bolts . . . 10-13.5 ft-lb*
Seat mount bolts . . . . . . . . . . 52-69 in-lb*
Sidestand nut . . . . . . . . . . . 10-13.5 ft-lb*
FUEL SYSTEM:
Air filter cover screws . . . . . . 50 in-lb*
Fuel tank bolts . . . . . . . . . . 10-13.5 ft-lb*
FRONT SUSPENSION / STEERING:
Fork bridge bolts - lower . . . . . 18 ft-lb
Fork bridge bolts - upper . . . . . 14.5 ft-lb
Fork cap air fitting (85-89) . . . . 5.7 ft-lb
Fork drain bolt . . . . . . . . . . 69 in-lb = 5.7 ft-lb
Fork slider Allen bolt . . . . . . . 14.5 ft-lb
Front axel pinch bolt . . . . . . . 9.5 ft-lb
Front axel nut . . . . . . . . . . . 43 ft-lb
Front brake disc bolts . . . . . . . 16.5 ft-lb
Front bevel geat case bolt . . . . . 8.5 ft-lb
Handlebar holder mounting Allen bolt 17.5 ft-lb
REAR SUSPENSION / FINAL DRIVE:
Brake torque rod bolt/nut . . . . . 22 ft-lb
Final drive - bearing case bolts . . 25 ft-lb
Final drive - drain plug . . . . . . 14.5 ft-lb
Final drive - mounting nuts . . . . 17.5 ft-lb
Rear axel nut. . . . . . . . . . . . 80 ft-lb
Shock absorber nuts . . . . . . . . 26 ft-lb
Steering stem bolt . . . . . . . . . 29 ft-lb
Swing arm retainer lock nut . . . . 9.6 ft-lb
post #2 of 13 (permalink) Old 05-07-2013, 10:47 AM
I don't like using the standard table, but the bottom 3/4 of that post is just what we need...
1 Vote for sticky post.
post #3 of 13 (permalink) Old 05-07-2013, 10:50 AM
Great Info !
+1
post #4 of 13 (permalink) Old 11-06-2013, 03:20 PM
Thank you
CSS13 is offline
post #5 of 13 (permalink) Old 01-08-2014, 01:42 PM
rsavant's Avatar
What about the engine mount bolts? I lost the nut and dampener from the upper rear mount bolt and have just replaced with OEM parts. If I really tighten the nut it seems to compress the dampener so I'm thinking maybe back off a bit and use lock tite. Any ideas?
rsavant is offline
post #6 of 13 (permalink) Old 01-08-2014, 01:49 PM Thread Starter
Back it off a bit and use loctite .....
It's so easy when they answer their own questions....
post #7 of 13 (permalink) Old 01-08-2014, 01:52 PM
rsavant's Avatar
Sounds like a plan! Thanks for the info. Stay warm, maybe we will get to ride again soon.
rsavant is offline
post #8 of 13 (permalink) Old 01-09-2014, 10:20 AM
I agree let's make this a sticy:thumbup:
post #9 of 13 (permalink) Old 01-27-2014, 10:14 AM
kemen3's Avatar
Where is a good place to get a torque wrench without breaking the bank. Harbor Freight has them advertise cheap but they have bad reviews, so I am hesitant about buying from there. Pep Boys has a good selection but I cannot find any reviews on them.
kemen3 is offline
post #10 of 13 (permalink) Old 01-27-2014, 10:18 AM
The pep Boys wrenches are junk.. I have an HF one, that gets used as a cheater bar becasue its not very accurate... Go with Sears or NAPA
