Whats your RPM at 100kph (62 mph) ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 67 (permalink) Old 10-29-2006, 06:26 PM Thread Starter
Hello Everyone,
I've recently bought a 1993 Vulcan 750; Its my first bike. Its in great shape and runs well but I have no baseline performance to compare it to.
I'm travelling at 100 kph (62 mph) on 5th gear and the tach reads close to 5000rpm. What do you think ? Is this about right or does my bike need tuning ?
Thanks.
ktullu
ktullu is offline
post #2 of 67 (permalink) Old 10-29-2006, 06:42 PM
Now what
Ironman's Avatar
Originally Posted by ktullu
Hello Everyone,
Thanks.
ktullu
Sounds right. Some people see the engine turning that fast and might think something's not right but the engine is made to run all day long at 5000 rpm. No problem. That is until the balancer comes loose, then all hell breaks loose. But that's rare and not something to worry about.
There's other stuff to worry about.
Like the end of the drive shaft where it engages the final drive. There are splines that need lubing with Moly 60. It's something that should be checked out.
If you've been riding the bike regularly and haven't had to charge the battery after riding every couple of days, the stator and R/R are probably ok. If the battery keeps dying, let us know. Someone will turn you in the right direction to figure it out.
Mostly you're going to find that the bike is a freakin blast to ride.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #3 of 67 (permalink) Old 10-29-2006, 06:44 PM
Once Banned
cegodsey's Avatar
Um, mine reads more like 70 on the speedo at 5K.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #4 of 67 (permalink) Old 10-29-2006, 06:54 PM
Now what
Ironman's Avatar
Guess we'll need to know what size tire he has on the front.
VROC 13864
Ironman is offline
post #5 of 67 (permalink) Old 10-29-2006, 06:56 PM
Once Banned
cegodsey's Avatar
True. I've still got stock. I guess it also matters what size tire on the rear. Again, I've got stock size.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #6 of 67 (permalink) Old 10-30-2006, 01:18 AM Thread Starter
I've got stock tires, according to the manual that came with my used bike.
I've just come back from another ride, not as windy this time. 5k rpm on 5th gear put me at 110kph (68mph) this time 'round. A bit closer to your figure, cegodsey.
By the way, the bike has only 12 000km on it if the odometer hasn't been tampered with. I'll check the splines, as recommended. Although I've had no problems yet with the battery I do plan on following the advice of relocating the r/r and changing to a maintenance free battery. I bought the bike earlier this fall and I've been riding it often since; the cool temperatures have probably kept some potential problems at bay.
Thanks again.
ktullu
ktullu is offline
post #7 of 67 (permalink) Old 10-30-2006, 02:25 AM
Once Banned
cegodsey's Avatar
Don't change anything you don't have to! Get a voltmeter ASAP, and then replace your battery with a MF when it's time. If you don't have one, get a battery tender. And do the r/r like you said.
5K at 68 is 'bout right. And a '93 with only 7500 miles is a blessing IF you aren't having trouble with a rusty tank. By the sounds of it, you aren't having those sorts of troubles!
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #8 of 67 (permalink) Old 10-30-2006, 02:53 AM
At 62mph, I'm probably a little over 4300, but under 4500 rpm's. Don't recall off hand what tire sizes I've got on there now though.
post #9 of 67 (permalink) Old 10-30-2006, 05:04 AM
Geek
rnewell's Avatar
At 70 MPH I read 4500 RPM. Stock tires.
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #10 of 67 (permalink) Old 10-30-2006, 05:08 AM
Once Banned
cegodsey's Avatar
I don't believe you. I mean, something is wrong for you to be showing that. Either someone has messed with the speedo, or the back tire is not a 150/90-15.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
