different years - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 10-25-2006, 06:39 PM Thread Starter
different years
Is there any difference between different years ? mine is an A10 so because there is a number change between each year does this mean they have changed bits and if so where can i find this info ?
Daz
dazbabes is offline
post #2 of 10 (permalink) Old 10-25-2006, 07:08 PM
Uber Member
i would say these bikes are about 99.99% the same from the vn700 on up.... there have only been a few changes along the way.....any questions on parts, ask here and we'll help u out
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 10 (permalink) Old 10-25-2006, 08:10 PM
Wiring harness(self cancelling signals went away) round verses square master cylinder and chrome to painted side coveres are a few things over the years.
Woody is offline
post #4 of 10 (permalink) Old 10-25-2006, 10:13 PM
Sky Rider's Avatar
Other than that, it's just been a color change for the most part. The cams on my 93 are stamped VN700 and the part numbers are the same in the micro fiches for the 85 and 93 cams.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #5 of 10 (permalink) Old 10-25-2006, 11:28 PM
Once Banned
cegodsey's Avatar
there is a file over in the yahoo section. Dianna or Hyper would be the ones that know where. Is this just general info you are looking for, or are you on a quest?
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #6 of 10 (permalink) Old 10-25-2006, 11:47 PM
HAWK
Ccspinner's Avatar
There was a change in the castings of the motor, cant rember what year I think mid 90's. There was a fin on the motor that moved location when I looked at 2 side by side. dont think any internal change though.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #7 of 10 (permalink) Old 10-26-2006, 04:38 AM
This was posted by 93VN750 a few months ago on this site.
It's not completely up-to-date, but just about......
Changes in the VN750 over the years
New Cost:
$5,500 (1985)
$5,500 (1987)
$5,500 (1988)
$_,___ (19__)
$6,090 (1995)
$6,090 (1997)
$6,090 (1999)
$6,190 (2000)
$6,190 (2002)
$_,___ (20__)
Air adjustable forks
- '85-'88 = only years
Brake master cylinder
- '85-'90 = rectangular
- '91-'06 = round
Brake Lever
- '85-'90 = same
- '91-'06 = changed
Clutch lever is the same for all years
Engine color
- '85 only = black
- '86- up = natural aluminum
Engine displacement
- '85 only = 699cc
- '86- up = 749cc
Fuel Cap latching
- '85-'87 = close without key
- '88- up = need key to close ????
Fuel Control Valve
- '85-'__ = RES - ON - PRI (Prime)
- '__-'__ = RES - ON - OFF
Fuel Tank rear vent tubes
- '85-'87 = none
- '88-'98 = tubes
- '99- up = none ????
Grab rails, Sissy bar, Passenger footpeg mounts
- '85-'86 = aluminum
- '87- up = chrome
Instrument bezels
-'85-'__ = aluminum
-'03-'up = chrome
Mirrors
- '__-'__ = rectangular
- '__-'__ = round
Oil filter
- '85-'94 = larger size 2.95" diameter
- '95 up = smaller size 2.76" diameter
Oil filter (mating) plate
- '85-'93 = 13169-1921 = 2.95" (75mm)
- '94 = 13169-1921 = 2.95" (75mm)
- '94 = 13270-1170 = 2.76" (70mm)
- '95 up = 13270-1170 = 2.76" (70mm)
Shock absorber
- '85-'98 = 45014-1304
- '99- up = 45014-1710 older ProTac brackets may interfer with air valve
reported by Jim "Pick" Foster
Side covers
- '85-'86 = Ebony
- '87-'98 = Chrome
- '99-'00 = Gray
- '01 only = Bronze
- '02 only = Black
- '03 only = Red
- '04 only = Ebony
- '05 ____ = _____
- '06 ____ = _____
Wheels
- '85-'86 = painted
- '87-'up = natural
Wiring harness
- '85-'88 have a Turn Signal Control unit
- '89- up Turn Signal Control unit eliminated.
- '85-'88 are NOT interchangeable with 1989 and up
Won't work by leaving the signal circuit open
__________
- '__-'__ =
- '__-'__ =
__________
- '__-'__ =
- '__-'__ =
Paint color listing:
http://f1.grp.yahoofs.com/v1/MKNSQ_P...D08M/color.xls
A # Year Tank colors Side cover
A 1 1985 _______ / _____ Ebony _____-____ & ____
A 2 1986 Black / Red L.V. Red 36002-5183-P5 & 5184-P5
A 2 86 Black / White Ebony 36002-5181-H8 & 5182-H8
A 3 1987 Black / Gray Chrome 36001-1359 & 1360
A 4 1988 Ebony / Gray " " " "
A 5 1989 Ebony " " " "
A 6 1990 Maroon / Black " " " "
A 7 1991 Maroon / Black " " " "
A 8 1992 Blue / Blue " " " "
A 8 92 Green / Green " " " "
A 9 1993 Blue / Gray " " " "
A 9 93 Green / Green " " " "
A10 1994 Green / Blue " " " "
A10 94 Red / Red " " " "
A11 1995 Green / Blue " " " "
A11 95 Red / Red " " " "
A12 1996 Red / Gray " " " "
A12 96 Blue / Silver " " " "
A13 1997 Red / Gray " " " "
A13 97 Ebony / G. Silver " " " "
A14 1998 Bronze / Red " " " "
A15 1999 Ebony / Gray P.C. Gray Blue 36001-1284-VK & 1285-VK
A16 2000 Ebony / Gray P.C. Gray " " "
A17 2001 Graystone / Bronze M.D. Bronze 36001-1284-7R & 1285-7R
A18 2002 Black / Silver P.G. Black 36001-1284-86 & 1285-86
A19 2003 Red / Graystone L.V. Red 36001-1284-2T & 1285-2T
A20 2004 Ebony / Silver Ebony 36001-1284-H8 & 1285-H8
A21 2005 Ebony / Silver Ebony " " "
A22 2006 _______ / _____ _______ -
post #8 of 10 (permalink) Old 10-27-2006, 07:20 PM Thread Starter
thanks for your help guys
dazbabes is offline
post #9 of 10 (permalink) Old 10-27-2006, 07:40 PM
HAWK
Ccspinner's Avatar
- '85-'87 = none
- '88-'98 = tubes
My 01 has 1 vent tube
Chad Falstad "Hawk"
Vroc #17649
post #10 of 10 (permalink) Old 10-27-2006, 08:23 PM
My '99 has one also.
Guess we can add that to the list.
Anyone have anything else we can make more up-to-date ?
This is for the Lurkers out there too !!
Why not make your first post one that contributes to the timeline of the history of the Vulcan 700/750.
Let's get this list complete, now that there aren't going to be any more !
