Stored for the winter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-22-2006, 11:14 PM Thread Starter
Rubline's Avatar
Well today I put the 750 to sleep for the winter. Added stabil to the full tank, Ran the engine until the carbs ran out of fuel, and fogged eached cylinder. Changed the oil, wiped down all the chrome with a oily rage. Put the bike on the center stand with a piece of plywood under each tire, removed the battery. and waxed the rest of the bike. Finally, I covered it with a sheet. BTW, bike is stored in an unheated shed. See ya in April.
Rubline is offline
post #2 of 11 (permalink) Old 10-22-2006, 11:18 PM
Sky Rider's Avatar
Look forward to hearing from ya this spring if not earlier.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #3 of 11 (permalink) Old 10-22-2006, 11:26 PM
You put it up allready? your weather can't be much different than mine, I'll ride until it snows(usually late Nov if I'm lucky) Did you let it run long enough to get the stabil into the carbs? if not probably no big deals since you drained them. I would rubberband some sandwhich bags over the tail pipes to keep out extra moisture and mice. Sounds like you got all the other bases covered cept maybe letting about 10-15 lbs of air presure out of your tires.
Woody is offline
post #4 of 11 (permalink) Old 10-23-2006, 12:03 AM
Once Banned
cegodsey's Avatar
Mice? That's what that smell was. First backfire of the year will take care of it, though.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #5 of 11 (permalink) Old 10-23-2006, 12:14 AM
Uber Member
then catch it and put the mouse in a sandwich
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #6 of 11 (permalink) Old 10-23-2006, 12:35 AM
Rider on the Storm
EasyRector's Avatar
Originally Posted by Rubline
Well today I put the 750 to sleep for the winter...
Sounds like you did everything by the book. Woody's suggestions are good.
I'm going to try to ride my bike all winter this year, keeping the battery on a trickle charger and taking it out for a spin every once in a while. In my neck of the woods there are a lot of days that are dry and 35-45 degrees. (Of course, I may change my mind if we plunge into a deep freeze for a month!)
EZC
EasyRector is offline
post #7 of 11 (permalink) Old 10-23-2006, 01:09 AM
HAWK
Ccspinner's Avatar
After all the talk about Seafoam here you used Stabil? Why would you want to hurt your bike like that.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 11 (permalink) Old 10-23-2006, 01:12 AM
Uber Member
2 words.....heated gear
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #9 of 11 (permalink) Old 10-23-2006, 06:27 PM Thread Starter
Rubline's Avatar
Stabil has been around alot longer than SeaFoam. I figure if its good enough for outboards and alike, its good enough for the Vulcan. As far as continuing to ride?,,, I enjoy riding but when I leave for work at 530am, I dont feel like freezing my kulunnes off. If both wheels are off the ground, why would I need to lower tire pressure? Ive never done it before with my trusty 74 Z1B or my 72 H2.
Rubline is offline
post #10 of 11 (permalink) Old 10-23-2006, 07:04 PM
fergy's Avatar
It will be interesting to refer back to this thread in the Spring. There is a large group of folks who claim that stabil does more to gunk up the carbs and cause today's gasoline to go bad even faster. There is a pretty good thread going right now on the yahoo group about this exact thing. They claim that seafoam is a better fuel stabilizer and will keep the deposits from forming.
I guess we'll find out.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
