Straight pipes or not? - Page 3 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #21 of 42 (permalink) Old 07-18-2012, 11:55 PM
Chucklehead
dragon159's Avatar
When I designed my system I wanted to give it a little more "growl" but not obnoxious, even though I will be the first to admit I am a bit of an a$$#ole, but recovering. I made the "muffler" out of 24" of 3 inch pipe and made an 18" baffle to fit in it. Gives a little growl but doesn't make babies cry when I go by.
my $.023
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #22 of 42 (permalink) Old 07-19-2012, 12:08 AM
Check my Paughco link in the other thread...besides, any used springer that fits a newer Sporty, will fit ours...gotta talk to my buddy tomorrow....he may have one...
post #23 of 42 (permalink) Old 07-19-2012, 02:33 AM Thread Starter
I'm not sure if the centers in my Dyna mufflers are catalytic converters or not. They have a center in them that looks like the honeycomb center of a converter.
You can't see through them, and they come off of an injected bike.
It appears there is some sort of a catalyst in there, but not sure what it is. so I'm going to knock the centers out of them, and see how they sound.
I was at one time leaning towards a set of super Trapp mufflers, but they are so damned expensive. So I will experiment with these mufflers, and see what they sound like in the end. If I ruin them I will just throw them in the trash, and start over.
I have a neighbor who has an older Harley and he has straight pipes with fishtail ends. They are true duals and the pipes go all the way to the end of the rear wheel, and they sound pretty loud, but he rarely ever gets on it in town or in the neighborhood.
When I was younger, I used to own a 72 Ford F150 with a built 390 with headers, 3 inch pipes with 5 inch stacks running through the bed right behind the cab with no mufflers. She was loud, but she sure sounded good.
I guess as I get older I want it somewhat quieter. My hearing isn't the best, but all the loud noises over the span of my life hasn't hurt my hearing too awful bad. I worked at a 1/4 mile racetrack, and I never wore hearing protection. Now I deal with the eternal burnout syndrome. Sucks.
TSmith68 is offline
post #24 of 42 (permalink) Old 07-19-2012, 03:04 AM
degoated mine and have dyna mufflers with a few holes drilled in the baffle.sounds pretty good
post #25 of 42 (permalink) Old 07-19-2012, 03:05 AM
my $.023
is there a support group for that?i would like to send my manager there.lol.cool. politically correct baby freindly mufflers.lol
post #26 of 42 (permalink) Old 07-20-2012, 06:50 PM
There aint no catalytic converters on Vulcans or Harleys (mebbe newer bikes, dunno)...ya got the goats belly, which is basically fixing an engineering screwup (making a crossover and expansion area because they screwed up the design)...other than that, anything you see are just baffles...
And you can put aftermarket baffles into straight pipes, then add the fishtail ends (still need the length though)...I know MANY who have done this, with great results....Triumphs, Harleys, Jappers, etc...
post #27 of 42 (permalink) Old 07-20-2012, 10:48 PM Thread Starter
I know the stock pipes on our bikes don't have anything in them other than the baffles.
As soon as I get one of these Dyna mufflers off, I will attempt to get some pics of the insides of them. They did come off of an injected bike. I know most of the older Harley mufflers you could see through them. These you can't.
TSmith68 is offline
post #28 of 42 (permalink) Old 07-20-2012, 11:05 PM
There might be a cat in the goat, not certian. I never opened it up. I would expect one in there though. I directly tossed mine in the trash when when I took it off. On the mean streak I had, I cut the goat and there was a small cat in it! Quit comparing foriegn with harleys! They are not the same! Foriegn have been keeping up with the times and technology, while harely is stuck in the stone age.
Rebel13 is offline
post #29 of 42 (permalink) Old 07-21-2012, 11:07 AM
Thats because most of the POs debaffled em...stock Harley muffs have baffles...took me awhile to get used Sporties with the baffles still in...
And nope, no cat in goat...one of the members here cut it apart (with pics, forgot who), and no pellets.
Then why do newer Sportsters have the same Showei forks we do ?...
Went down like this : the Japs coppied the Harley design to get that market, but improved on it. Then Harley (since they lost all their good engineers) began to use/copy Jap parts. So in effect yer contradicting yerself. There are so many Jap parts on a Harley now, it aint funny. AND...the aftermarket companies saw this, improved on both (usually),and started offering that fer options. My old Harley ran same points (yep, points) as a Chevy 6 cyl...nowadays Harley uses Nippon-Denso in many bikes...so why not compare, unless youre comparing with an older Harley. Same stuff.
post #30 of 42 (permalink) Old 07-22-2012, 01:53 PM Thread Starter
These Harley mufflers have a center that looks like the center of a cat. Small tight woven honeycomb design from the inlet side. I haven't looked at the outlet side. They are not your typical baffles if you can even call them that.
I have never seen a center like that in any muffler, even the older sporty's.
TSmith68 is offline
