750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 03-17-2012, 08:43 PM Thread Starter
my 96 750 runs great til it warms up then seems like it loses power to back half of engine any ideas?
vulcan98 is offline
post #2 of 18 (permalink) Old 03-17-2012, 09:36 PM
Member? ... check.
ZCraggRatt's Avatar
To me it sounds electrical. Start cheap. Consider swapping the pickup coils to see if the problem moves to the front cylinder. Check resistance of both to see that they fall within spec.
Also, while you're in there, consider the pickup coil mod to bring both pickups to .020" of the flywheel. I would check for spark with a timing light on all plug wires. Anything suspicious would get further inspection.
After getting the bike warmed up where it is failing, run it in a dark area to see if you are leaking a rear cylinder spark to ground somewhere abnormal.
Not that it is related, but if you don't have iridium plugs, consider putting them in.
Worst case, the IC ignitor may have some thermal expansion issue.
~~C8>
ZCraggRatt is offline
post #3 of 18 (permalink) Old 03-18-2012, 08:59 AM
Or it could be the sparkplugs breaking down under pressure
Swagman is offline
post #4 of 18 (permalink) Old 03-18-2012, 10:52 AM
Member? ... check.
ZCraggRatt's Avatar
^ x2
Check those plugs for proper gap, fouling or cracks.
post #5 of 18 (permalink) Old 03-19-2012, 06:04 PM Thread Starter
ok, i changed pickup coils and now back cylinders work but front dont
vulcan98 is offline
post #6 of 18 (permalink) Old 03-19-2012, 06:28 PM
Sounds like a bad pick up coil maybe then if you swapped them like ZC said
Try this link https://www.vn750.com/forum/archive/i...hp/t-3430.html
Swagman is offline
post #7 of 18 (permalink) Old 03-19-2012, 07:10 PM
Sounds like you are using up the fuel in the carb bowl, and then it takes a little while to refill. Feul restricktion to rear carb.
post #8 of 18 (permalink) Old 03-20-2012, 11:40 AM
Member? ... check.
ZCraggRatt's Avatar
I think if it were me, I would move the good pickup coil back to the front cylinder and purchase a new one for the rear. This will keep your wire color code per schematics.
I would also do the pickup coil mod to .020", and put in the iridiums.
Part# 59026-1062 COIL-PULSING
Better check that part# with the part distributor.
Good luck.
~~C8>
Edit: Not sure, but the pickup coils may come as a set.
post #9 of 18 (permalink) Old 03-20-2012, 07:18 PM
Crap, I WAS in 5th gear.
If you run out of options, get stumped, or are tired of swapping parts around, iridium plugs require less voltage to spark, so they may keep you going (at least for a while) until you have an outright failure which may be easier to diagnose.
Kelly2001 is offline
post #10 of 18 (permalink) Old 03-24-2012, 11:22 PM Thread Starter
ok, i found out that there was a short in wire /plug for voltage regulator, repaired that and bike now has 12v to all coilsbut now it will not charge. if i shut it off i have to put a charger on it to start it again. whats chance of alt/stator still good?
vulcan98 is offline
