digital manometer - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-17-2012, 02:33 PM Thread Starter
digital manometer
Has anyone used something like this:
http://www.ebay.com/itm/Digital-Mano...item35aeb24f2a
I am interested in knowing if this would be useful for synchronizing the carbs on the VN750 as well as a few other uses I have in mind for this.
I do not know what vaccum range I would need to read for the carbs, so maybe someone here can tell me if this is useful.
The listing shows specs:
The device measures Gauge/Differential Pressure from -55H2O to +55H2O(+2 psi).It features 11 selectable units of measure:
inH2O,psi,bar,mbar,Kpa,InHg,mmHg,ozin2,FtH2O,cmH2O ,kgcm,Additional features include Data Hold and Auto Power off disabled.Careful use of this meter will provide years of reliable service.
post #2 of 6 (permalink) Old 03-17-2012, 04:16 PM
HAWK
Ccspinner's Avatar
Sure you could use one like that but you can make one with clear hose and a yard stick.
there is a diagram on here somewhere.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 6 (permalink) Old 03-17-2012, 04:26 PM
BTD
Have you ever tried using those though? Sure its doable, but it sure is a pain!! I did it on a four cylinder, so I'm sure a twin isn't quite as bad but still!
Be ready to shut the engine down because the slightest difference in vaccum and you will be sucking oil into one of your cylinders faster than you can adjust the carbs
BTD is offline
post #4 of 6 (permalink) Old 03-17-2012, 04:33 PM
two vacuum gauges work well also and swap em after you finish and see if the both read the same,to be sure.Or test them both on the same vacuum source and adjust accordingly.
post #5 of 6 (permalink) Old 03-17-2012, 09:57 PM
Well, to actually answer your question, I am guessing the two tubes sticking out at the top mean you can compare two diffrent vacuum lines at the same time.... So yes, it should work for syncing the carbs on he 750.
Not sure what else you plan to use it for, but it can tell you how much something sucks.......
post #6 of 6 (permalink) Old 03-18-2012, 07:42 AM Thread Starter
This little unit is certainly inexpensive enough to give it a shot. It does in fact give you the "differential" pressure between the 2 input ports, so the goal would be to adjust the carbs so the diff. press. (in this case, vacuum) is reading zero.
As for what else I can use it for....avionics gauges for one....pressure output for small pumps and other things I like to "tinker" with.
Does anyone know about how much "vacuum" pressure these carbs develop? I just want to make sure the meter is able to cover the range of vacuum for each port.
I am thinking somewhere around 12-15 InHg ??
