Seafoam - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 28 (permalink) Old 02-27-2012, 09:24 AM Thread Starter
Seafoam
Yippee been on Ebay today and I found a supplier of Seafoam in the UK so I have place an order for a can and will see if it is as good as you folks say
Swagman is offline
post #2 of 28 (permalink) Old 02-27-2012, 12:06 PM
rev it up's Avatar
hmmm,interesting !. I just been out today and bought from "Boyes" 3.35. Its STP Petrol treatment,it says it cleans all the carbs,valves,rust (RUST) and emissions. Do you think it will be as good as seafoam ?.
AGEING IS INEVITABLE,,MATURING IS OPTIONAL
VN 750 A8 1992.
27000 miles.
Imported from California
to UK in 1996.
New for 2012.
new filters(foam type)
replacement shocks(MDI)
Iridium plugs.
AGM battery(platinum)
brake pads(Kyoto)
(All on and running)
rev it up is offline
post #3 of 28 (permalink) Old 02-27-2012, 12:27 PM Thread Starter
I'm not to sure but they all seem to have simailar ingredients so maybe, I've since been checking up and found that Redex which has been on the market here for around 60 years is basically the same also
Redex contains a whole bunch of solvents that dissolve just about any type of gunk you might find in your engine. The main ingredient is Kerosene (paraffin) but it also contains acetone (as in Hammerite thinners/nail varnish remover), toluene and xylene.
Swagman is offline
post #4 of 28 (permalink) Old 02-27-2012, 01:26 PM
flitecontrol's Avatar
Sea Foam contains naptha, light oil, and ethanol.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 28 (permalink) Old 02-27-2012, 01:54 PM
There are alot of products on the market that are "simular" to SeaFoam ...(in the claims made on the label as to what they can do) but only SeaFoam has the reccomendation of the vast Vulcan community.
This is not saying some of the other products do not work. Am sure some of them do as advertised. But there have been countless testimonials about the wonders of SeaFoam through the years on this, and other motorcycle forums.
So, it is the one most of us trust and use.
post #6 of 28 (permalink) Old 02-27-2012, 02:01 PM
rev it up's Avatar
I dont dispute that at all !....But have you seen the PRICE of seafoam over here in the dreary UK.
VN 750 A8 1992.
27000 miles.
to UK in 1996.
New for 2012.
Iridium plugs.
brake pads(Kyoto)
post #7 of 28 (permalink) Old 02-27-2012, 03:50 PM Thread Starter
Unfortunately yes I have but I thought I may aswell give it a go bearing in mind the bike has been stood for 13 years and if it works well on it we will know why all the guys on here rave about it
Swagman is offline
post #8 of 28 (permalink) Old 02-27-2012, 04:14 PM
JM2001's Avatar
SeaFoam does everything as advertised but the main thing is that it won't dissolve gaskets and seals which is important on our older engines.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #9 of 28 (permalink) Old 02-27-2012, 04:26 PM Thread Starter
Thats good to know and I would not have ordered it if I didn't believe what I read on these forums, this is not product advertising but good and solidly tested results by a great number of knowledgable people, i hope/expect to get some great results
Swagman is offline
post #10 of 28 (permalink) Old 02-27-2012, 04:57 PM
JM2001's Avatar
I have been using it for 30 years, both in motorcycles and outboard motors. It was developed in the 1930's to clean the gum and varnish from 2 stroke outboard engines which was created by mixing the gas and oil. The SeaFoam name comes from this application. IIRC
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
