Broken Bolt. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 02-22-2012, 06:34 PM Thread Starter
MaDeInSin's Avatar
Broken Bolt.
Hey All-
I was installing my coasters today and one of the bolt heads on the left side reed valve broke off... Now the good news is I have about 1/4 of screw head to play with once I take the reed off... Any ideas about the best way to get this sucker out? Would an impact driver be my best bet?
Part of me is thinking to run it to a mechanic and they prolly wouldn't charge me a lot to remove it but what are your thoughts?
Thanks Guys
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #2 of 10 (permalink) Old 02-22-2012, 07:22 PM
I'd take a file, file two opposite sides so there a little flat, and then hit the bolt with penetrating oil. Let it sit overnight, then clamp it with a pair of vice grips (at a right angle if possible) and try turning it out carefully.
The bolts not that big, but on larger ones I've drilled a hole through the side through the bolt and pushed a steel pin in it. Easy to grab with even regular pliers.
But I always pre soak with liquid wrench first.
post #3 of 10 (permalink) Old 02-22-2012, 07:41 PM
Or if you have a tap handle you could clamp that on and turn it
post #4 of 10 (permalink) Old 02-22-2012, 08:52 PM
JM2001's Avatar
If you can't get it with the vice grips you could file it flush, drill a small hole in it and use an EZ out
http://www.sears.com/shc/s/p_10153_1...1&blockType=G1
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 10 (permalink) Old 02-22-2012, 10:51 PM
Patriot Guard Rider
The DEUCE's Avatar
Hit it with PB Blast and remove with Vise grips!
VN750 #9300 & VROC #33453
The DEUCE is offline
post #6 of 10 (permalink) Old 02-23-2012, 11:38 AM
X2 on the PB Blast....works every time for me
post #7 of 10 (permalink) Old 02-23-2012, 01:07 PM Thread Starter
MaDeInSin's Avatar
Thanks all. Picked up some vise grips from sears on the way home. About to attempt to crank this bolt out. I sprayed it last nite and again this morning with pb blaster. So we shall see. Quick question. When I took off the Reed valve cover there was no gasket. Where do I install this gasket. Between the coaster and the Rees valve or the reed valve and the bike?
Thanks
Accomplishments;
Iridium Plugs
Lubed the Spline
Re-Jetted
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
post #8 of 10 (permalink) Old 02-23-2012, 01:47 PM
Let's Ride!!
DaveT319's Avatar
Another possibility is if you have a Dremel tool you could cut a channel in the end of the bolt with a cut-off wheel so that you can use a flat-head screwdriver to get it out.
DaveT319 is offline
post #9 of 10 (permalink) Old 02-23-2012, 02:04 PM Thread Starter
MaDeInSin's Avatar
Got it Out!!!!!! Thanks all!!! I hit it with PB Blaster.. Filed down two sides as KM Suggested... Latched the Vise grips on and out it came... Thanks everyone for your help..
I also figured out the answer two my second question.. Coasters are installed :-)
Now... lets go see if the poppin is reduced!
Thanks Again!
Accomplishments;
Iridium Plugs
Lubed the Spline
Re-Jetted
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
post #10 of 10 (permalink) Old 02-23-2012, 03:26 PM
Great. Glad it was easy for you. Most of my experiences with easy outs have not been so easy! lol
