fenders - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 02-19-2012, 05:37 PM Thread Starter
fenders
Hey guys and gals new here you have probably talked about this before but I'm looking for the older style full fenders with little to no mods to do I'm new to the bike game bud not to machanic work so any help with the fenders would be verry aprishiated
TheEDGE is offline
post #2 of 13 (permalink) Old 02-19-2012, 06:20 PM
I believe the front fender from an early 1980s GL1000 or 1100 Goldwing will fit the vn750 by only slightly elongating the mounting holes.
Can`t help with a rear fender though.
Goldwing GL 1000 or 1100 front fender on Dianna`s sidecar rig:
https://www.vn750.com/photopost/showp...ppuser=23&sl=d
post #3 of 13 (permalink) Old 02-19-2012, 07:07 PM
Interesting that this came up...Ive been thinking same then adding whitewalls (poor man's dresser). I was gonna try ElectraGlide fenders as i can get em cheap from a friend.
And a note on the rear....it will need to be hinged to be able to remove the rear wheel easily (Harley rears are).
post #4 of 13 (permalink) Old 02-19-2012, 07:28 PM Thread Starter
Thank good idea with the harley fenders I have found a fiberglass fender called a ganster fender but it 450 or more I can get a bland for 80 bucks but getting some one to modifiy it might cost more. All and all this is still just a idea for me still waiting on income tax to see if I even get the bike
TheEDGE is offline
post #5 of 13 (permalink) Old 02-19-2012, 07:38 PM
I remember my 72 Shovelhead FLH having a hinged rear fender but it wasn't long after that they came with solid rear fenders,
I would like to find one of those earlier FL fenders and I would stick it on the back of my !500 Classic ,it made tire changing a breeze on the old "Glide."
post #6 of 13 (permalink) Old 02-20-2012, 04:11 AM
Ah, seems like Harley was innovative way back then. A hinged fender. Interesting. To bad they never put centerstands on their old bikes (or new ones) with tube type tires to make it possible to fix a flat beside the road. People crossed the country on old Knuckleheads and Panheads, Indians, etc. with tube type tires and no centerstands, and I know they had flats. I have never found out how they dealt with them.
Back in the late '90s, there was a company called Hard Krome, or something like that, that made steel Indian type fenders for various Japanese cruisers, I was just looking through my collection of Motorcycle Cruiser magazines and found the ads.
I have an '85 1200 Goldwing, and the front fender is nothing like an Indian fender. It has a little bit more coverage, but I don't think it's the look your after.
IMO, the Vulcan 750 would not make a good dresser, the overall look is wrong. A dresser needs a much smaller diameter front wheel, much wider front tire, lower bars, and more importantly, a different frame layout. Also consider the Vulcan's weight limit. Kawasaki did make a "Tour Pack" for the Vulcan 750 once, but the price for all the parts was like over $2500, and my guess it weighed so much that there was not enough load carrying capacity left for a single large person.
If you want a real dresser, that doesn't break the bank, then look for an '80-'87 Goldwing. I have seen several converted to "baggers", with whitewall tires, cut down windshield, removal of the fairing lowers and rear trunk. A solid color paint job, and you have to look twice to make sure it is not one of those machines from Milwaukee. Those old GW engines have been known to go past 300,000 miles.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #7 of 13 (permalink) Old 02-20-2012, 07:13 AM
earlier pans and knuckles did have a stand that flipped down from the rear of the frame and lifted the rear wheel off the ground,you were kinda on your own on the front,but back then with the tube type you could break one side of the tire down and repair a tube without removing the whole wheel and every body doing any traveling in those days via two wheels usually carried a bicycle pump and tube patching.Back in the earlier days breakdowns were the norm and you learned to be pretty self sufficient.
post #8 of 13 (permalink) Old 02-20-2012, 10:31 AM Thread Starter
Love the feed back the waight hadn't crossed my mined also the goldwing ideathat they would pull of the look better I had never even consiterd. I do have a buddy at work who's got two gl1100 for sale an80 and81 for 1500 bucks for the pair I might look in to those as a project bike but if any one here is an old goldwing fan ill point you in there direction cause the 750 will be my first bike hopefully in the next few days
TheEDGE is offline
post #9 of 13 (permalink) Old 02-20-2012, 06:27 PM
I quickly became an old Goldwing fan when I got my '85 about a year ago. It was given to me in non running condition. I spent all last summer rebuilding everything but the engine itself, which was fine. I have put several thousand trouble free miles on it since then. I belong to FIVE Goldwing forums, all of them very good, with lots of people willing to help you. Even had one local member GIVE me a rear wheel when mine turned out to be trashed due to being run with a bad bearing. There is probably more support for Goldwings than all other Japanese bikes combined. Lots of parts are no longer available new, but between eBay and lots of places that sell reproduction and used parts, it's unlikely a needed part won't turn up soon.
1979 Vespa P200E
post #10 of 13 (permalink) Old 02-20-2012, 08:25 PM Thread Starter
Then let me ask you would it be worth the 1500 fo both goldwings one needs carb work the othe the same probably but also all the plastics are off the bike I've seen both but new to the hole motorcycle thing I'm suppose to be getting the 750 from my dad for cheap is y I'm hear to learn about it open to all bike though
TheEDGE is offline
