Need hep? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 02-19-2012, 09:58 AM Thread Starter
2002 VN 750
Need help?
I have been told my 02' 750 needs the case split to fix my shifter, is it easier or less expensive to swap the motor/tranny than to split the case.
If so what should be swapped out and would it save money to swap?
Any other info would be very helpful.
02' Kawasaki Vulcan 750
35,000 miles
Leather saddle bags
No mods
firefighter068 is offline
post #2 of 13 (permalink) Old 02-19-2012, 11:35 AM
It all depends on what the problem is. Your info here is not enough to give a good answer.
post #3 of 13 (permalink) Old 02-19-2012, 11:37 AM
JM2001's Avatar
Maybe an easy fix. Not enough info given. Could just be the shifter pawl spring. check this thread
https://www.vn750.com/forum/showthrea...t=shifter+pawl
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 13 (permalink) Old 02-19-2012, 11:55 AM Thread Starter
2002 VN 750
Sorry guys, I guess the shaft is broken inside from what I was told.
The mechanic has told me the cases need to be split.
They went in throught the rear clutch case area and the linkage is attached.
So there for the case needs split, I am looking at about 900-1000 dollars to fix it.
I didn't win the lottery so that is why I am trying to find less expensive options, or am I stuck with spliting the cases?
What more info do you guys need me to find out?
Thnk you in advance.
35,000 miles
Leather saddle bags
No mods
post #5 of 13 (permalink) Old 02-19-2012, 12:36 PM
JM2001's Avatar
We are very skeptical here. What is the year of bike and mileage? What is the problem with the transmission ( symptoms )? I guess you were told either the input shaft or output shaft was broken. You are being quoted an expensive repair so make sure it's needed.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 13 (permalink) Old 02-19-2012, 12:45 PM Thread Starter
2002 VN 750
to Jm2001
My bike is an 02' it has 36,000 miles on it
The shift lever just flopping up and down, it is
stuck in 1st gear.
The mechanic tells me it already has the quick fix of placing
a piece of metal between the case and shifter lever to keep
the shifter shaft from sliding in and out.
They told me that the linkage is intact?
I was then told the the shaft was broken.
Is the repair worth it?
My bike is in excellent shape, well maintained.
35,000 miles
Leather saddle bags
No mods
post #7 of 13 (permalink) Old 02-19-2012, 02:11 PM
JM2001's Avatar
to Jm2001
stuck in 1st gear.
Your bike is not old and not that many miles. I doubt any shaft is broken. I still think it's related to the shifter pawl, either frozen or broken. I would also check the linkage between the shift lever and acctuator for breakage. The case has to be split in any case so you're paying a lot in labor.
I think the bike is worth it if you bought it right although 2 VN 750s with less than 10,000 miles each sold for less than $2700.00 at a dealer, one a 2002 and one a 2004.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #8 of 13 (permalink) Old 02-19-2012, 02:22 PM
Doesn't it also stay in 1st gear when the pall spring has come off or broken
Swagman is offline
post #9 of 13 (permalink) Old 02-19-2012, 02:29 PM
flitecontrol's Avatar
The earlier bikes had a shift rod that would eventually break. They fixed that and yours is the heavier, improved shaft.
Unless you really trust the mechanic to know what he's talking about, I'd be dubious about what he says is wrong.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #10 of 13 (permalink) Old 02-19-2012, 10:39 PM
I would check the spring on the left side of the engine before going into the engine. I believe that is in the part that houses the beveled gears. Go here and check some of this vids.
https://www.vn750.com/forum/showthread.php?t=18289
