Battery testing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 12-05-2011, 08:06 PM Thread Starter
Battery testing
I know that a very vigorous crank is required to start these bikes. I generally use my 100 amp load tester to test my batteries. However I'm thinking that would melt our little batteries. What type of load should I test with?
RobertGary1 is offline
post #2 of 11 (permalink) Old 12-05-2011, 08:48 PM
I always just gave the battery a good charge, then installed it, connected a voltmeter to it, and used the starter as a load. Watch the voltage drop as the starter turns the motor over. If it quickly drops below 10 volts, the battery is no good.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #3 of 11 (permalink) Old 12-05-2011, 11:07 PM Thread Starter
That makes sense. Although a weak starter will also result in good voltages held.
-Robert
post #4 of 11 (permalink) Old 12-06-2011, 09:08 AM
That's true. You can check the amp draw on the starter, and see what it is. I don't know what it is supposed to be, but it should be in the manual. I personally believe the Vulcan 750 has bot a too small battery, and a too weak starter to begin with. Both my Vulcan 750s have turned over noticeably slower than most of my other bikes, even when new. But, they are also the only v-twins I have ever owned until getting a Harley Road King. It too turns over fairly slow. Could be just a v-twin thing. My recent 500 Ninja would turn over really fast, as does my 250 Rebel and 1200 Goldwing. I can't help but think that the Vulcan 750s slow cranking speed has something to do with it sometimes being hard to start. It may not be turning over fast enough to have a good spark.
1979 Vespa P200E
post #5 of 11 (permalink) Old 12-11-2011, 07:36 AM
Your best bet is to take it to any auto parts store for FREE testing. They can compare the CCA's of the battery to what it is rated at.
When we were having starting problems with our 1990, I took our battery (which the previous owner said was NEW) in for testing, and it actually tested higher amps than it was rated at, ruling out the battery as the problem.
-Ric
Aufgeblassen is offline
post #6 of 11 (permalink) Old 12-11-2011, 12:55 PM
cglennon's Avatar
Before purchasing my VN750 I mined this forum for the pros and cons, know issues and general information. Unanimous was the consensus that a strong AGM type battery was the best solution for many of the bikes starting problems (especially when warm). Many thanks to everyone here! So, the first thing I did when I purchased my VN750 was to replace the O.E. wet battery with a good AGM battery (Yuasa brand). That solved the endless crank to start the engine (especially when the engine was warm). Since then I've added Iridium spark plugs and K&N air filters (again thanks to the recommendations and help from this forum). Near instant starts now when the engine is warm and maybe up to 3 cranks when cold. Going on 4 years now and everything is still going strong, no starting issues, no performance issues and no battery issues. I am a convert that a really good AGM battery is a requirement for this bike. So, I would say replace your current battery if; it is more than a few years old, China made, not AGM, completely drained in the past, suspect in any way, etc.
Chris Glennon - Portland, OR
cglennon is offline
post #7 of 11 (permalink) Old 12-11-2011, 04:02 PM
A rule of thumb is engines always start WAY better warm/hot than cold. If not, then something is definitely anominal with said engine.
-Ric
post #8 of 11 (permalink) Old 12-12-2011, 10:27 PM
Love My Baby
rubyrick's Avatar
Not necessarily. My baby starts right up when cold (although in Florida cold isn't that cold!) with the choke on full, but starting up when warm the choke must be off and it always seems to hesitate just a bit. Always starts up though, except for the rare POOGS issue.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #9 of 11 (permalink) Old 12-21-2011, 07:12 PM Thread Starter
Autoparts store says they don't have anyway to test motorcycle batteries. Their load testers probably work off 100-150CCA. I have a load tester myself but its min is 100CCA, likely enough to cook these little batteries.
-Robert
[QUOTE=Aufgeblassen;195058]Your best bet is to take it to any auto parts store for FREE testing. They can compare the CCA's of the battery to what it is rated at.
post #10 of 11 (permalink) Old 12-25-2011, 02:12 PM
Try a different store, because the tester they have at our Advance Auto Parts store has a wide range of selectable nominal CCA's for testing.
