frame mod or save - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 11-12-2011, 10:00 AM Thread Starter
brett13501's Avatar
frame mod or save
https://www.vn750.com/photopost/data/..._brett_212.jpg
https://www.vn750.com/photopost/data/...camera_181.jpg
https://www.vn750.com/photopost/data/..._brett_290.jpg
https://www.vn750.com/photopost/data/..._brett_291.jpg
this is the bike with the left side of frame cut off by po. we found a donor frame and got a section. before fitting and after. note the v section cut out of middle of picture. sorry about the quality. v cut out served a separate use as i was missing the v off of the side cover. total coincidence the v fit almost perfect. need to paint to match and attach.
waiting on frame weld this weekend and then time to reassemble bike.
brett13501 is offline
post #2 of 9 (permalink) Old 11-12-2011, 11:41 AM
Huh?
All I see is a photo of a side cover. Not sure what you are talking about...
post #3 of 9 (permalink) Old 11-12-2011, 04:37 PM
Those pictures are way too small to see anything. They need to be like 6"x8". I would not try to save a cut up frame. Look for a complete frame with a title. If you do decide to weld in a section, I hope you are a good welder. I have found Japanese motorcycle frames to be a lot thinner than I originally thought they were. I don't think they can be safely butt welded without some kind of reinforcement.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 9 (permalink) Old 11-12-2011, 08:04 PM Thread Starter
brett13501's Avatar
sorry about pix. they looked fine in the mebers gallery when i brought them from phone to thread. will try to take some better photos that don't exceed limit.
we have slugs inside of the tubes to reinforce them. talked with a body guy that has made his own bike and he said it would be a strong enough weld.
post #5 of 9 (permalink) Old 11-14-2011, 02:46 PM Thread Starter
post #6 of 9 (permalink) Old 11-14-2011, 03:41 PM
Looks good. Putting slugs in there was definitely a good idea. If the frame is straight, and you trust the welding, I'd say it is ok. I wish Kawasaki had put the removable section on the left instead of the right, that way the stator could be replaced without pulling the engine. The GL1200 has it on the left.
1979 Vespa P200E
post #7 of 9 (permalink) Old 01-20-2012, 05:54 PM
Amsoil Man's Avatar
I see ya stick welded? Any special reason for that? Whit the thin steel It might have made it more brittle ya think. I had done the same Mod last fall, plus I halve pipe clamped her.Im sure she has less Vibrations then she did before. Ya had a good idea.Now if ya need another stator(which you should never need one) it will only take 1 hr and out on the road again.
Amsoil man
Pick ups reset
Splines lubed
Kenda Kruz tires 110Frt. / 170 rear
Custom saddle seat
Backrest
1500 classic rear fender
Cobra slants /Custom Made turndowns
Diamond Plate Buffalo Leather Bags
Throttle lock
Front bearings repacked
Front shock oil replaced
Led bulbs
Amp meter
Running Boards
Dial A Jet Carb settings
Gremlin Bell (front mount)
Fully Lubed with Amsoil Lubricants
Trailer hitch / Hidden
Your Local AMSOIL Connection! Cell#989-329-1225
Amsoil Man is offline
post #8 of 9 (permalink) Old 01-20-2012, 11:01 PM
I have wondered if there is any good reason why Ma Kaw couldn`t have put a removable sub-frame on BOTH sides of the Vulcan frame instead of just one side?
The only reason that I can see is that some unskilled owner might try to take both sides off at the same time, resulting in damage or injury.
post #9 of 9 (permalink) Old 01-21-2012, 12:11 AM
HAWK
Ccspinner's Avatar
That looks like a fluxcore wire feed gas less.
Kinda a hot welder but easy to control, the slug was a great idea, you did sand teh rust off first after that picture right. Rust will kill a weld.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
