Suggestions when looking at used VN750s? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 11-01-2011, 03:08 PM Thread Starter
Hi everyone.
I have been looking around for my first bike and I came across a few Vulcan VN750s in my price range. I have found two that I plan to look at.
I was wondering you had any specific pointers when looking at older Vulcans? I don't want to overlook some common problem areas, nor do I want to pay too much. Any recommendations in these areas would be greatly appreciated.
Here are the two I plan to look at.
1986 VN750 - $1300 - 24k miles - owner has owned it since 9k miles - no other details other than that at this stage. Pictures look promising.
1988 VN750 - $1200 - No miles listed but considered 'running great' with no mechanical issues. Registration is out a month. Pictures look promising as well.
Any help would be great. Thanks all!
post #2 of 25 (permalink) Old 11-01-2011, 04:37 PM
Vulcan Drifter
DevinWolfe's Avatar
Check through the link below, in my opinion the most important thing to look for is the safety equipment. I found that my new (to me) bike did NOT have fully functional (rear brake pedal) lights. That was an easy fix, but I should have looked better.
https://www.vn750.com/forum/showthread.php?t=1191
DevinWolfe is offline
post #3 of 25 (permalink) Old 11-01-2011, 06:24 PM
If only it had 6th gear..
DavesVulster's Avatar
X2 on the safety. And the useful link.
Off the top o the skull I'd say bring a voltmeter, put the leads on the battery and rev the engine to around 3k and watch the volts. Should climb up to 13.5 or more at that rpm. If it doesn't you might be uncovering a stator or regulator problem. Stator - serious (because of the work involved) and regulator - semi-serious. I'd ask for $300 off if you discover a charge issue??? I don't know if that's fair but others will advise.
Then look at battery terminals, starter terminal and other electrical connectors like the fuse box fuse box under left side cover (regulator and harness is under the battery) for corrosion.
Check cable linkages, (throttle, choke, clutch etc.) for rust or fraying.
Look at front fork seals for seepage/cracks and tires for dry rot.
If you can't test ride it, put it on the center stand while running then put it in 1st gear and listen to the shaft drive while idling, no need to run thru the gears or rev it and see if it's quiet. Many of these bikes were never lubed at the factory and if the drive is loud - could be big problem.
And last, if the owner doesn't want you to pop the seat and look around under there, I'd think twice about buying it from them. Good luck, they're great bikes if cared for properly. Sorry if too much info but not knowing how much you already know, I put it out there.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #4 of 25 (permalink) Old 11-01-2011, 09:21 PM
Here is a link to the table of contents for the Vulcan Verses:
https://www.vn750.com/forum/verses.php
You may find a few other helpful topics up in the first section too.
Take a 1/4" drive ratchet wrench , a 3" extension, and a 10 mm socket with you along with the volt meter, when you go to look at the bikes. You will need the socket wrench to remove the 2 bolts inside the toolbox that hold the seat on.
Here is a link on how to read the date code on tires, and determine if they are too old to ride on:
http://blog.unsafemotorcycles.com/20...e-matters.html
Read the Grambo trick in the verses. If you hear the noise in either of the cylinders, try turning the screw tighter in the ACCT to see if it quiets down. It is not a deal breaker, just a price bargaining point.
Hope this helps.
post #5 of 25 (permalink) Old 11-02-2011, 11:51 AM Thread Starter
My thanks to all three of you for the helpful information.
I'll definitely do my due diligence in regards to the safety gear on the bike - I planned on checking the brakes but I am not sure I would be as thorough as I will now.
I should be looking at one of them tonight. With the resources and suggestions presented I feel I'm at a much better position to make a proper decision. I also appreciate the thoroughness DavesVulster as this really is my first forte into two wheels and my mechanical experience is mostly related to general cars and trucks.
Cheers everyone. Super helpful site and if I pull the trigger I can see myself coming here regularly.
Cheers!
post #6 of 25 (permalink) Old 11-02-2011, 11:16 PM
Glad to have you here. Good luck and I'm happy we could help. Let us know how it goes and if you end up with a new family member from the mechanical realm take pics if you can. Take care.
Dave
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #7 of 25 (permalink) Old 11-03-2011, 12:09 AM Thread Starter
Thanks for the warm welcome Dave.
I just got back from checking out the 1986 listed for $1300. Here's the rundown.
-Shape was good for a bike of her age. She is stored outdoors under a cover currently, so it shows she is not a show bike - but - she is clean.
-The owner had changed the stator fairly recently. He seems to have developed a small leak around the wire-grommets where I am personally guessing it was not sealed properly. I have seen a few posts relating to that here so it seems common.
-The owner believes the thermostat is stuck on as the bike does not like choke when starting cold and it stays very cool. I, again, found several topics in relation to this. We're located in southern California, and 'cool' is around 55-65. I'm not sure if the bike has a bad thermostat or just runs cool in our climate.
-This hose (see image) wants to come off occasionally.
Other than that, fair tread on the tires, around 7k left safely. I was unable to check the voltage. It hasn't been laid down, it's in pretty clean/fair condition. The aftermarket pipes are loud, and sound good to me. I heard no backfires but it wasn't ridden much.
If you all give the seal of approval to continue looking at it, I will go back and have a friend who has far more riding experience give it a test ride personally.
Your help has been greatly appreciated thus far, and I hope I'm not asking too much of the forum. Thanks again!
Additional pictures below.
post #8 of 25 (permalink) Old 11-03-2011, 01:28 AM Thread Starter
Back again.
I had just made a post, but it seems to have disappeared - so I'm going to re-post without images in case the spam filter thought I was a baddie.
I just got back from checking out the 86 750 w/ 24k miles - asking price of $1300.
The bike looks in good shape for the age. No scrapes on the engine or anything that would signify a drop of any sort. Some tank wear - typical dings from rocks and such. The tires have about 6-8k left in them - the owner states 10k but I wouldn't risk it.
-The owner replaced the stator somewhat recently. It has developed a small leak - seemingly from the wire-grommets are. I would assume these weren't sealed correctly from the few posts I've seen here on the subject.
-The owner believes the thermostat is stuck open, thus making the bike run cool. I'm in Southern California, so it never really gets that cold here to begin with. I have seen a decent bit of posts asking why their bike never gets warm, even after replacing the thermostat. Thoughts on this? He also states that the bike never likes choke to be used at all.
-The owner has had the larger hose that comes off the carburetor (i think) - near the idle adjustment - pop off during rides occasionally. He recently re-tightened it well and hasn't had it come off yet.
If my other post appears, it has more descriptive pictures as well.
If it looks like its worth perusing, I will re-visit with my friend who has a lot of riding experience to give it a test ride. I appreciate all of your input and really appreciate the warm welcome Dave.
post #9 of 25 (permalink) Old 11-03-2011, 09:16 AM
The Vulcan 750's 2 biggest problems, (IMO) are the automatic cam chain tensioners, and the rear drive splines. The cam chain tensioners will destroy the engine if they fail, fortunately they usually make a lot of noise some time before a lot of damage is done. If I bought a used Vulcan, I would replace those things with manual tensioners to start with, and avoid the problems. Mine failed at about 15,000 miles. A new set failed 10,000 miles later. Went to manual, and 45,000 miles later everything is ok.
The splines on the rear drive were apparently not lubed right at the factory, causing many to suffer significant damage even before the manual called for servicing them. Also, many people who just assumed a shaft drive was maintenance free never messed with them at.
These are the two most expensive possible issues with the Vulcan 750, unfortunately there is no way to check the final drive splines without tearing the rear end apart. Listen for a loud or unusual rattling noise from the engine, if you here something like that, it is probably the cam chain, But it takes a little experience to tell for sure. The Vulcan 750 engine has an unusual amount of mechanical noise compared to most motorcycle engines, probably because there are about twice as many moving parts in it. VERY complex engine, but a lot of power for a 750 v-twin cruiser as well. My '02 has lasted 70,000 miles so far, but was bought new, has been well maintained and not abused.
These engines seem to have more problems due to neglect than anything else.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #10 of 25 (permalink) Old 11-03-2011, 10:53 AM Thread Starter
Thanks for the reply Jerry. I had the owner throw it up on the center stand and put it in first and listened for noise at the splines - I didn't hear anything really negative sounding - and according to one of the posts that's archived here - it should be somewhat noticeable if it is an issue.
In regards to the cam chain tensioners, I didn't hear anything crazy from the engine but then again I wouldn't know what to listen for in this regard.
