throttle sticking and bad responce - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 10-16-2011, 02:31 PM Thread Starter
My throttle (the actual twister on the bars) sticks real bad, when i twist it a little and let it go it doesnt snap back like it should, but keeps the bike revved up, also it doesn't have very good response to it.
Is this something i can fix, or does it need replaced? If so, where could i get the parts.
ironcowboy is offline
post #2 of 11 (permalink) Old 10-16-2011, 02:43 PM
flitecontrol's Avatar
Sounds like mine when I bought it. The throttle cable was frayed, and eventually broke near the handle. Suggest you remove the cable from the throttle handle, inspect, and either replace or lube as indicated.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 11 (permalink) Old 10-16-2011, 02:45 PM Thread Starter
Ok thanks, where would i get new cables?
post #4 of 11 (permalink) Old 10-16-2011, 02:51 PM
cheapcycleparts.com (cheap but slow shipping) ebay, kawi dealer, Motion Pro and lots of other places.
"Black Beauty"
Old Blue
post #5 of 11 (permalink) Old 10-16-2011, 03:03 PM Thread Starter
Awesome! Thanks,
Which of the two cables on cheapcycleparts am i going to need for my 94?
post #6 of 11 (permalink) Old 10-17-2011, 02:09 AM
Originally Posted by ironcowboy View Post
Awesome! Thanks,
labor time / effort virtually the same, I would replace both....will make a big difference.
good luck
post #7 of 11 (permalink) Old 10-17-2011, 11:29 AM
It was the pull cable that went out on mine, but replacing both isn't a bad idea. Be sure to lube them if they don't come that way.
"Black Beauty"
Old Blue
post #8 of 11 (permalink) Old 10-17-2011, 05:55 PM
If only it had 6th gear..
DavesVulster's Avatar
Awesome! Thanks,
cheap cycles has an online parts manual built into the site. Just enter your bike info and look in the cables and control section.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #9 of 11 (permalink) Old 10-17-2011, 06:05 PM
Ceal's Avatar
I find that if mine are routed wrong the throttle sticks too... Might wanna try moving them around and see if they get loose at some point. If something is pressing against them or if there's too much of a bend or something it can cause this too.
Ceal is offline
post #10 of 11 (permalink) Old 10-17-2011, 06:52 PM Thread Starter
thanks guys, much appreciated!
