Spray oil coating for storage.. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 10-10-2011, 08:30 PM Thread Starter
If only it had 6th gear..
DavesVulster's Avatar
Hi guys. A few years ago I bought this spray oil that I coated all the metal parts on my bike with prior to putting it in my shed. When i pulled it out in spring and hosed it off it looked like new. I can't for the life of me remember what it's called. I also use fogging oil but this stuff is specifically for coating the bike (or whatever you're trying to protect). It had a tackiness to it so it was great protection and didn't run off over time. Anybody know what I'm talking about? I need to buy more :-/
Thanks all.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #2 of 21 (permalink) Old 10-10-2011, 08:44 PM
OldHipWesTex's Avatar
Send a message via Yahoo to OldHipWesTex
Ya didn't save the can did ya?
Vulcan #1 1993 - 28K
Vulcan #2 1999 - 26k
It All Comes Down To 3 Things:
#1 Fuel
#2 Spark
#3 Mechanical
Any One Fails - Then It Dont Run
____________________________________
ANTICIPATED MODS:
Build Fiberglass Fenders F/R
Mold & Cast New Turn Signals Lights
OldHipWesTex is offline
post #3 of 21 (permalink) Old 10-10-2011, 11:40 PM Thread Starter
funny thing about that. I left it outside one season and the label turned to mush over winter. I'm going to stop by the hardware store where I bought it and see if they'll know. i found it by accident initially so maybe I will again.
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #4 of 21 (permalink) Old 10-11-2011, 11:34 AM
You might want to look for 'overspray mask.' There are several kinds, but it's a spray on/wash off product that keeps paint overspray (clever, eh?) from settling on parts you don't want painted, but are too far from the painted area to be worth masking with paper/tape.
2005 VN750 upwards of 14K (haven't looked lately)
Mods:
AGM Battery
Degoated
Headers wrapped
Custom paint
hot_rod_hippie is offline
post #5 of 21 (permalink) Old 10-11-2011, 01:22 PM
I just use WD-40. It was specifically designed to protect the bare aluminum surfaces of stored aircraft from moisture induced corrosion, it leaves a long lasting film, but can still be easily washed off. It also protects steel parts from rust.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 21 (permalink) Old 10-11-2011, 04:20 PM Thread Starter
Thanks guys. I was thinking about wd40 but I didn't know if if would eventually run off. This stuff was almost like an invisible glove. It'll be inside so the wd should do it but I'll look into overspray mask as well. Thanks for that tip too. That stuff will come in handy for some projects and I didn't know it was available
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #7 of 21 (permalink) Old 10-11-2011, 05:05 PM
Roach's Avatar
ACF-50?
Edit: Or Scottoiler FS 365?
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #8 of 21 (permalink) Old 10-11-2011, 05:18 PM
Here's the overspray mask I use:
http://www.autobodytoolmart.com/usc-...5-p-16001.aspx A gallon goes a long way, and it's water soluable.
Hippie
Mods:
AGM Battery
Degoated
Headers wrapped
Custom paint
post #9 of 21 (permalink) Old 10-11-2011, 05:27 PM Thread Starter
Thanks! that seems even better since you can put it on the plastic and rubber parts as well?
Dave
Mods:
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Tunes
post #10 of 21 (permalink) Old 10-11-2011, 05:37 PM
Have you thought about using PAM?
It's non stick and can be had in olive oil of butter flavor.
