Bike stalling, not idling comfortably, giving me heart palpitations - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 09-16-2011, 01:53 PM Thread Starter
Hey all,
So in my heart of hearts I think (hope) this must be a simple problem.
The other day I started up the bike just to run 'er for a little bit and enjoy the sound only to have a few, brief seconds of running followed by endlessly cranking the battery starter to no avail.
I decided to give it some time and wait till tomorrow. My gut was telling me the engine wasn't getting gas, for some reason, so I did nothing. This morning I could get it started but had to hold the throttle open to maintain any kind of run. Also there was a lot of sputtering and unevenness from the exhaust.
Any kind of help is greatly appreciated. I'm still learning how to diagnose these problems; hope it isn't a biggie.
drizdan is offline
post #2 of 14 (permalink) Old 09-16-2011, 02:00 PM
Member? ... check.
ZCraggRatt's Avatar
Hi drizdan,
Make sure you have a good charge on that battery before trying again.
Kinda sounds like low battery power. The VN750 demands a good strong battery to run properly.
~~C8>
ZCraggRatt is offline
post #3 of 14 (permalink) Old 09-16-2011, 02:30 PM Thread Starter
No, it's not the battery.
Special update! Now the bike is back to not starting again. I feel like it's a question of fuel. Intake outtake back break I don't know.
drizdan is offline
post #4 of 14 (permalink) Old 09-16-2011, 03:14 PM
Member? ... check.
ZCraggRatt's Avatar
ok ...
Have you pulled the plugs to see if they are wet with fuel ?
Have you checked to see that the petcock delivers fuel to each carburator ?
Have you checked that the carburator float bowl fuel levels are good ?
Have you looked for vacuum lines cracked, broken, or disconnected ?
~~C8>
post #5 of 14 (permalink) Old 09-16-2011, 03:19 PM
Member? ... check.
ZCraggRatt's Avatar
Can you tell if there is good compression in the cylinders?
Does running the choke on full make a difference?
Crack open the carb fuel bowl drains, and see if you have fuel in the bowls.
Have you checked to see that you are getting a nice fat blue spark at each spark plug?
Check some stuff out ... and let us know some more info ...
~~C8>
post #6 of 14 (permalink) Old 09-16-2011, 03:33 PM Thread Starter
Update update: I pulled the spark plugs and took a look. The rear two are fine, the front two are black and wet. How do I check compression? The fuel hoses all seem to be fine. How can I check the float bowl levels? I'll go crack the drains and see if there's fuel.
drizdan is offline
post #7 of 14 (permalink) Old 09-16-2011, 03:50 PM
Crobins365's Avatar
I check compression by pulling the spark plug, detaching it from the wire, and moving the wire way, way far away from me. Place your thumb against the now-open spark plug socket and turn the engine over - you should feel suction against your thumb. Someone else may have a more accurate - or safer! - way to do this.
When was your bike last ridden? Might just need a thorough carb cleaning.
C
Crobins365 is offline
post #8 of 14 (permalink) Old 09-16-2011, 06:46 PM
Dry the spark plugs and let the cylinder air out. Give the plugs a good brushing and re-enstall. Try and start engine.
post #9 of 14 (permalink) Old 09-16-2011, 11:12 PM
Also, if you haven't been riding much then maybe you should try new gas in case you got some moisture in it and add some seafoam.
post #10 of 14 (permalink) Old 09-17-2011, 10:30 AM
If only it had 6th gear..
DavesVulster's Avatar
Sounds like a stuck float in the front cylinder wet and black plugs = too much fuel. If you're going to use your finger to do a quick check on compression, do it from the side with the short spark plug cap. It's shallow and easier to get your finger on it. I think your front cylinder is flooding with gas tho. You should make changing your oil a high priority after you fix this since it may now have gas in it. Good luck. Hope you get er running.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
