Performance Woe, no top end - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 09-09-2011, 10:14 AM Thread Starter
Recently purchased 2001 vn 750. Engine purrs but won't roar. 5th gear, around 4,200 rpm, 70mph,,, that's it. Nothing indicates an engine problem other than lack of top end. Feels as if a governor was put on this machine, otherwise runs great.
Appreciate if anyone can provide a scenario of things to troubleshoot before I take it into a shop.
Coder is offline
post #2 of 7 (permalink) Old 09-09-2011, 10:23 AM
Check the hose that fits into the back of the right airbox...pull it out, cut the end at a 45 degree angle and stick it back in.
Can you rev the bike up towards redline in neutral ?
Make sure the throttle is opening all the way, and there are no airleaks around the carbs.
You are using regular gas right?
post #3 of 7 (permalink) Old 09-09-2011, 10:25 AM
flitecontrol's Avatar
Have you tried half a can of Sea Foam in a tank of fresh gas? I'm guessing a carb issue, but someone else may have another idea. IIRC, mine hits 70 mph around 5,000 rpm. And yes, it should have plenty left after that.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 7 (permalink) Old 09-09-2011, 10:33 AM
My VN 750 has been earshaved and not jetted so only does about 70 to 80 top speed, getting new jets this tuesday so will be fixed and back to top speed.
I also had a power problem were on inspection i had a torn carb diaphragm now this is fixed i can pull off fast but until the jets are in my carbs i still cant get to full speed.
Sounds like you could have a carb problem, im not too good with mechanics but hopefully my little carb problems can give you a little insight to what it could possibly be.
MajorChop is offline
post #5 of 7 (permalink) Old 09-09-2011, 11:10 AM
How about an exhaust restriction.
post #6 of 7 (permalink) Old 09-09-2011, 02:27 PM Thread Starter
Follow Up
No redline in neutral: 8grand, throttle does open all the way, will investigate airbox hose and carb leaks. Thanks for response.
Coder is offline
post #7 of 7 (permalink) Old 09-09-2011, 05:29 PM
Just my 2c...
Sounds like fuel starvation to me.....
...check for good fuel flow as well...its both gravity and vaccuum, so check filter at petcock, the hoses like Knife stated, and the cap vent.
