900 Kawasaki Owner ??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 08-22-2011, 08:59 AM Thread Starter
JM2001's Avatar
Anyone here own a 900 Kaw? I need some info to help a friend out.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #2 of 6 (permalink) Old 08-23-2011, 10:45 AM
I don't but my bro-n-law does. He has me do his tinkering. I'll help if I can. What's the issue?
post #3 of 6 (permalink) Old 08-23-2011, 11:17 AM
Ron_G does, hit him up...
LibertyPilot is offline
post #4 of 6 (permalink) Old 08-23-2011, 12:15 PM Thread Starter
JM2001's Avatar
Sending PM
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #5 of 6 (permalink) Old 08-23-2011, 12:27 PM Thread Starter
JM2001's Avatar
Thanks, I sent Kanuck a PM, if that doesn't help I'll try Ron.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 6 (permalink) Old 08-23-2011, 03:55 PM
I replied to the PM but thought I'd add the infor here as well.
"The Vulcan has a rising rate linkage on the rear shock, meaning the leverage changes as the shock absorber compresses. The more it compresses, the stiffer the suspension gets.
Now for all you owners wondering where to set the preload adjustment, I am going to throw this unconventional idea out there: the softest setting is #7, the one that raises the back of the bike highest. This is not the only bike I have had with this type of suspension and they all seem to work the same way – softest ride is on the maximum preload. This heretical idea goes against the common wisdom which says the softest ride is at the lowest preload setting.
Which, by the way is bull, even for a simple rear suspension that has no links or levers. Feel free to ignore the advice of all the well meaning Vulcan owners who suggest lowering the suspension for a softer ride. Setting it at 7 may not work for you if you have short legs, or if you have smooth roads and want the low customized look, but for me it's a set it and forget it deal.
There is no situation where I need to adjust it down. Admittedly, the suspension is still a bit stiff, but that is the because of the original shock, which feels even stiffer at lowered settings. There is an additional benefit of more ground clearance, which this bike lacks in some situations."
