speedo stopped working - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-17-2011, 03:41 PM Thread Starter
Well i took the bike to get some lunch and on the way back my speedometer stopped working. I took the cable end off and attached my drill to it and i got movement in the speedo. Took the front wheel off and examined the speedo mechanism by the hub. Everything seemed to be working fine not sure what I should do. Any suggestions?
Dan
Dan Prez is offline
post #2 of 7 (permalink) Old 08-17-2011, 03:53 PM
knees in the breeze!!!
Tofer76's Avatar
put the cable on the gear and take it off the guage and see if the gear moves the cable
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #3 of 7 (permalink) Old 08-17-2011, 03:54 PM Thread Starter
found this link of parts
http://www.cheapcycleparts.com/model...semblies/73634
the part 41078 is that entire assembly. If i bought that whole unit would it fix my problem?
Dan Prez is offline
post #4 of 7 (permalink) Old 08-17-2011, 03:55 PM
Crobins365's Avatar
Try lubing the mechanism on the hub. I've used graphite in the past for lubing a speedometer, but maybe someone else has a more appropriate suggestion.
C
Crobins365 is offline
post #5 of 7 (permalink) Old 08-17-2011, 04:22 PM
Hmmm, seems like I had a bit of a problem once when I removed the wheel & brake mech., can't remember exactly what it was though...
Other than makin sure everything was engaged & in place right, I would try removing the cable & sheath and cleaning with something like Kerosene, then lube with something like "Lock-Ease", which is a colodial (sp) graphite as Cindy suggested...
If that don't work, maybe you need a new cable...
post #6 of 7 (permalink) Old 08-17-2011, 05:24 PM
Take the wheel off & inspect the reciever for the spedometer (mounted to the wheel). This is part # 41064. If it is damaged it can slip past the spedo drive unit & give the symptoms your describing. I would suggest taking a pic of it & posting it so we can inspect it. Mine had gone bad & I was able to repair it temperarilly by recutting the edges nice & square. This got me by till my new one came.
If your getting movement through the cable & registering on your spedometer & the drive unit itself is functioning I'm going to guess your reciever has gone bad. Don't ask me what would cause it to go bad cause I don't have a clue. I couldn't figure it out myself.
post #7 of 7 (permalink) Old 08-17-2011, 09:48 PM Thread Starter
the edges on the reciever were square( that was the main part I looked at), I tried turning it by hand and it seemed a little stiff. Anyways im taking a trip on the bike to new york tomorrow( about 4 hours). I guess ill have to do without a speedo until i get back...
Dan Prez is offline
