removal of speedo and tach help please - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-15-2011, 04:01 PM Thread Starter
jwk
I am trying to remove my speedo and tach in order to refinish and paint them. Yes it is the common rusty rings and chipped chrome housing that I am trying to address. I know there are screws on the back of the housing cups on each of them and removing them just frees the cups from the units themselves. Can someone please provide guidance in what I need to do to remove the gauges, cups and all in order to repaint them. I have seen several great posts on how to refinish and repaint them but none on getting them off. Any help would be greatly appreciated! Thanks!
jwk is offline
post #2 of 7 (permalink) Old 08-15-2011, 04:39 PM
clock152's Avatar
I have to do the same to mine.. I was looking and I belive that you have to remove the head light bucket to get to the screws on the back/underside of the housing between the speedo and Tach.. once that is off you can access the brackets holeing the speedo and tach on.
clock152 is offline
post #3 of 7 (permalink) Old 08-15-2011, 05:02 PM
Down load the repair manual. All the parts diagrams & such are in there. You can look at the expoded view & see how it all goes together.
Start on Pg. 291 for directions of removal.
post #4 of 7 (permalink) Old 08-15-2011, 07:19 PM Thread Starter
jwk
thank you so much for the guide to the repair manual, I can see where the headlight needs to be dropped and then the bolts can be removed to take them off, Thanks again this was a huge help. Now just needs to stop raining here so I can do it!
jwk is offline
post #5 of 7 (permalink) Old 08-15-2011, 08:28 PM
Bronson's Avatar
I recently removed the speedo by unscrewing the back cover and then unbolting the bracket inside the housing. I did not need to remove the headlight housing to do so.
If the headlight is also rusted, you may want to remove it anyway.
Bronson
2005 VN 750
Plexistar windshield
.040 pilot jets.
Splines lubed 1955 mi.
Iridium plugs
Reset pickup coil gaps.
Metzeler ME=880s
Shindengen MOSFET RR
V & H Cruzers
Degoated
Speed bleeders
MCCTs.
Bronson is offline
post #6 of 7 (permalink) Old 08-15-2011, 11:53 PM
scuba's Avatar
it's in the clymer book. Otherwise remove the headlight, and 2 screws for the back plastic piece. and you will see the nuts inside.
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
post #7 of 7 (permalink) Old 08-16-2011, 01:21 AM
If only it had 6th gear..
DavesVulster's Avatar
I took mine off the same as Bronson. Had to revive my trim rings also. I don't get why Kaw didn't clear coat those rings. I liked the way they looked at first but get a little mist in the air and you got rust. Didn't get around to clear coating mine and then they got too bad so satin black was the weapon of choice. That Krylon "Fusion" paint seems to cover pretty well by the way.
DavesVulster is offline
