Thinking about getting this headlight. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 07-26-2011, 10:45 AM Thread Starter
I put LED turn signals on my Vulcan but they don't support running lights. So I was thinking about picking this up to add running lights back on the bike. Just wondering if you think it will fit as a replacement headlight... http://cgi.ebay.com/ebaymotors/Demon...Q5fAccessories
Spock
'93 750 Vulcan
DONE
Ear Shave
Re-Jet
EMGO Handlebar
MeanStreak Seat
Oversize Tires
Custom Skeleton Mirrors
Maintenance Free Battery
LED Halo Headlamp
LED Brake Light
LED Turn Signals
Hard Saddle Bags
Custom Plate Mount
Highway Pegs
Custom Skull Radiator Cover
All New Lines and Cables
Custom Neon Green Plug Wires
Iridium Spark Plugs
Kevlar Clutch Plates
PLANNED
Spline Lube
Fork Tubes Rebuild
Freeswilly is offline
post #2 of 14 (permalink) Old 07-26-2011, 11:26 AM
If only it had 6th gear..
DavesVulster's Avatar
Wow that's pretty sweet lookin'. So are you going to mount running lights where your original signals go? Its a great idea. Should fit without a problem as long as the diameter is the same. The casing doesn't look any bigger. Post pictures if you do it. I'd love to see.
DavesVulster is offline
post #3 of 14 (permalink) Old 07-26-2011, 11:36 AM
Diameter is important, but in the case of the Vulcan , so is depth. A few have found that the stock bucket was too shallow for some aftermarket headlight reflectors.
I think Dianna used a headlight shell from another bike as the stock one was not deep enough for the reflector she bought.
post #4 of 14 (permalink) Old 07-26-2011, 01:54 PM Thread Starter
I have LED turn signals that I put on where the stock ones were. They however don't support running lights so I would use the lights on the headlight for the runners.
Spock
'93 750 Vulcan
DONE
Ear Shave
Re-Jet
EMGO Handlebar
MeanStreak Seat
Oversize Tires
LED Halo Headlamp
LED Brake Light
LED Turn Signals
Hard Saddle Bags
Custom Plate Mount
Highway Pegs
Iridium Spark Plugs
PLANNED
Spline Lube
Fork Tubes Rebuild
post #5 of 14 (permalink) Old 07-26-2011, 02:31 PM
Ok I understand now (takes a while). I was thinking you were talking "auxilary" lights. Musta not been awake enough on the 1st post. Anyway, I hope the measurements work cause it's a cool idea.
post #6 of 14 (permalink) Old 07-27-2011, 10:55 AM
knees in the breeze!!!
Tofer76's Avatar
would they show up very well as our headlights are on all the time ??
i am toyin with the idea of putting driving lights where the stock signals go and the mouting led turns lower on the fork tubes
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #7 of 14 (permalink) Old 07-27-2011, 10:58 AM
KidChaos's Avatar
Just an FYI. What I did was get LED replacement boards from custom dynamics that are white for my front TS. I moved them down to the forks using the memphis shade relocation brackets. Also replaced the amber covers with clear ones.
They are super bright driving lights, and still function as TS
I will take a pic later today and post it here
KidChaos is offline
post #8 of 14 (permalink) Old 07-27-2011, 11:08 AM Thread Starter
I bought the headlight and it should be here later nextweek. Ill post pics when I get it installed.
Spock
'93 750 Vulcan
DONE
Ear Shave
Re-Jet
EMGO Handlebar
MeanStreak Seat
Oversize Tires
LED Halo Headlamp
LED Brake Light
LED Turn Signals
Hard Saddle Bags
Custom Plate Mount
Highway Pegs
Iridium Spark Plugs
PLANNED
Spline Lube
Fork Tubes Rebuild
post #9 of 14 (permalink) Old 07-27-2011, 08:07 PM
lphernan's Avatar
I also don't think they will show up when the headlights on. Hopefully I'm wrong for your sake. Kind of expensive too. Hope you like them.
Louie
1995 VN750 - Work in Progress
2001 BN125 - Learning Bike
2004 GL1800 - All Done
lphernan is offline
post #10 of 14 (permalink) Old 07-28-2011, 08:52 AM
Yes they will show up fine.... As long as they are not too close to the headlight (even so...you still have more light visable..)
See photo here in daylight:
http://m.flickr.com/#/photos/knifemaker1954/1489996347/
