Need name and part number of a hose - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 07-22-2011, 01:54 PM Thread Starter
Well after being away for a while, finally got back on the bike and did the rear spline lube. After going over everything well i noticed that the rubber hose that comes out of the side towards the top of the rear cyclinder is cracking. What is the exact name and if anyone has the part number and where i could get it would be great. Thanks alot this forum is great.
fisher1630 is offline
post #2 of 15 (permalink) Old 07-22-2011, 01:56 PM
Stones750's Avatar
I can definately help you out here but need to clarify. Do you mean the coolant hose that connects to the rear cyl. head with the little curved tube???
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
post #3 of 15 (permalink) Old 07-22-2011, 02:06 PM Thread Starter
Yes i believe so, it is the soft rubber hose, not the line coming out of the top of the cylinder
post #4 of 15 (permalink) Old 07-22-2011, 02:10 PM
Stones750's Avatar
kaw PN : 39062-1102 : hose-cooling if you need new protectors (look like springs wrapped around the tube their part number is: 49124-1051. Hope this helps!
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
post #5 of 15 (permalink) Old 07-22-2011, 02:25 PM Thread Starter
Just to confirm i circled the part in the picture to make sure we are talking about the same one. Thanks for your help.
post #6 of 15 (permalink) Old 07-22-2011, 02:59 PM
Stones750's Avatar
Ok so the picture is a bit to tiny to make out but I think the hose you want is whats coming off the reed valve assem. Im going to do some digging and see if I cant track that part number down.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
post #7 of 15 (permalink) Old 07-22-2011, 03:03 PM
Stones750's Avatar
KAW PT # is 92059-1618, This is the hose that connects from the reed valve assem. to the air cut off switch. I personally do not have that stuff on mine anymore to check so please double check before ordering. Im 99 percent positive this is what you need.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
post #8 of 15 (permalink) Old 07-22-2011, 03:29 PM
Go to sell and trade let every one here know what you need. I am sure you will find one here.
post #9 of 15 (permalink) Old 07-24-2011, 03:03 AM Thread Starter
Thanks, will do. What exactly is the function of this tube.
post #10 of 15 (permalink) Old 07-24-2011, 12:39 PM
It helps cool the engine from the lean air fuel mixture. And at the same time it helps EPA system burn the fuel completely in the goats belly.
