its coming along!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-16-2011, 12:54 AM Thread Starter
knees in the breeze!!!
Tofer76's Avatar
Talking its coming along!!!!
well i finally got all the leds for the dash and gauges of my 94 750
and tonight i put them in also installed the volt meter w relay
used ground in bucket and ran hot from relay that is mounted on the battery hold down bolt
switched power is from a red wire going into the brain
funny thing is that my voltage drops a bit when im on the move but goes back to 14vdc when idleing??
and when i hook up a blue red wire in the bucket my headlamp warning comes on but both the high and the low work just fine???
i also got a couple rubber caps for the reed valves and have no poping now yaaaaa
have not removed all the rest of the emission stuff yet
got my k&n filter for my single filter ear shave today too but i need to get the jets so i can do it
and found out that the thumb adjuster for the choke is broken and i need a new one
Question:: when i ear shave there are hoses in the front of the airbox that go to the cylinder on the front do i just cap them like the reeds??
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #2 of 4 (permalink) Old 07-17-2011, 07:31 PM Thread Starter
Tofer76's Avatar
well volt gauge is acting normal now not sure what it was
i do have a question tho : when im idleing the right side pipe gets a little bit of a stutter and when i decelerate it might give off one pop but not always
any ideas ???
VROC# 33976
1994 VN750
MODS SO FAR:
Tofer76 is offline
post #3 of 4 (permalink) Old 07-17-2011, 10:39 PM
The hose at the front left is the engine vent. You can get a small pod filter at a parts store.
On the volt varience check the battery ground at the frame.
post #4 of 4 (permalink) Old 07-17-2011, 10:48 PM
KidChaos's Avatar
About the pop. I had that too. Try adjusting air mix screw on carb on opposite side as pipe. But, mine. Did not go away until I ear shaved
KidChaos is offline
