repair manual? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-10-2011, 12:25 PM Thread Starter
repair manual?
I found an actual shop manual for the 85 VN700/750 but it says its for the A1 models (canadian) WOULD THAT STILL COVER MY BIKE OR ARE THEY ALOT DIFFERENT? THANKS
hoggs750 is offline
post #2 of 5 (permalink) Old 07-10-2011, 01:36 PM
What model is your bike? You have no signature line, and I don`t remember what you have.
Is it a Kaw shop manual from the first year JUST for the 1985 Canadian model?
I have a Canadian bike, and about the only differences for the 1991 (A7) are the emission control canister, hoses and factory coasters.
The early models do have some differences outlined here:
https://www.vn750.com/forum/showthread.php?t=1771
The info for working on all the major systems except those identified above are the same.
Ask about any specifics if you aren`t sure.
post #3 of 5 (permalink) Old 07-10-2011, 03:14 PM Thread Starter
I have a 1985 VN700...and the manual says it is for the canadian models it is an actual Kawasaki manual
hoggs750 is offline
post #4 of 5 (permalink) Old 07-10-2011, 08:00 PM
IMO, the main differences you will find are the emissions controls and coasters mentioned in my first post, less the smaller cylinder/piston diameter specs for the 700 cc engine. The rest of the engine parts are interchageable, including the heads.
Not really a big deal because the 700 piston rings are no longer available for a rebuild anyway.
However, you can swap 750 cylinders and pistons as a set onto a 700 engine case.
The Canadian manual will cover 99% of everything you are likely to need to do.
We should be able to fill in any missing info.
post #5 of 5 (permalink) Old 07-10-2011, 11:40 PM Thread Starter
ok..awesome thanks for the help
hoggs750 is offline
