5th gear?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 06-26-2011, 05:25 PM Thread Starter
5th gear??
Hi all... New rider here.. Took my 2003 VN750 on the highway for the first time (the Taconic for those in NY), going 60-65 in 4th gear at 5k RPM - and 70-75 in 4th gear at 5.5k RPM, I ended up staying in 4th the whole time. So I was thinking - when do ya'll shift to 5h gear?
Shay
Shaygonen is offline
post #2 of 15 (permalink) Old 06-26-2011, 05:50 PM
flitecontrol's Avatar
Unles accelerating quickly, I shift around 3,500 rpm.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 15 (permalink) Old 06-26-2011, 05:53 PM
I guess it depends on how & where you are ridin, crusin roads with no fun I would shift my vn750 into 5th anywhere around 3.5-4k just for crusin, in the twisties is a bit of a different story and she got run on up there open throttle or for hold back...
On my present bike (1200 Sportster) I would say about 1K less in the rpm range, its geared a bit higher but is a shade lower rpm bike, I've only seen 7.1K on it, where I have seen the red line on vn750 many times... I think at 7.1K on the Sportster it was probably bumping the (stage 1) rev limiter, the vn750 does not have a rev limiter...
I think you will get a lot of different answers on this...
post #4 of 15 (permalink) Old 06-26-2011, 07:22 PM
Concert connoisseur
wib714's Avatar
wehave a 5th gear? LOL
I usually shift to it between 55-60 unless I'm gettin on it!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #5 of 15 (permalink) Old 06-26-2011, 09:48 PM
IMBoring25's Avatar
It'll take 5th without complaining at 25, provided you don't put it under much load. Cornering in 5th is possible in some situations.
On the other end of the scale, I like to get to merging speed before doing the last shift or two, so that would be 65-70+ in some cases.
IMBoring25 is offline
post #6 of 15 (permalink) Old 06-26-2011, 11:50 PM
Heading to the DARKSIDE!
BRET H's Avatar
5th gear....that's the gear that I am in when I always try to shift into the 6th gear that Ma KAW forgot to install on our bikes....HA HA!
BRET H is offline
post #7 of 15 (permalink) Old 06-27-2011, 06:55 AM
Guess what... I still do that, even though my bike is geared much higher than the vn750, I'm thinking that it's mostly a habit to make sure we are in the highest gear...lol...
post #8 of 15 (permalink) Old 06-29-2011, 03:43 PM
rev it up's Avatar
thats three of us then !. im always looking for 6th gear....lol. Wait for it now,someone will submit a thread with the heading "is it possible to install a 6th gear. lol.
rev it up is offline
post #9 of 15 (permalink) Old 06-29-2011, 03:52 PM
It's already been asked..........twice if I remember right.
I shift into 5th right after 4th.......
post #10 of 15 (permalink) Old 06-29-2011, 04:22 PM
baldy's Avatar
Shay
I'm confused at your numbers shaygonen.
When I am in 5th gear at 70-75 mph I am at 5 to 5300 RPM.
1 question.... When you start from neutral, do you shift down for 1st?
It seems that you ARE in 5th gear at the RPM you stated.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
