1996 vn 750 trike - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 06-18-2011, 05:43 PM Thread Starter
1996 vn 750 trike
Well decided to take the two wheel to three so my mother in law can have the pleasure to ride. just want to give the forum some pics. I would like to thank the forum it has hepled with some issues with the bike. I will try to keep pics going as it progresses or time.
sorry for the first picture size
ID:	3836   Click image for larger version
ID:	3837   Click image for larger version
ID:	3838   Click image for larger version
ID:	3840   Click image for larger version
Name:	vulcan rear end.jpg
keithtified is offline
post #2 of 26 (permalink) Old 06-18-2011, 06:02 PM
Concert connoisseur
wib714's Avatar
can you resize those, they are really small!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 26 (permalink) Old 06-18-2011, 06:02 PM
We need bigger pictures!
vulcanpower is offline
post #4 of 26 (permalink) Old 06-18-2011, 06:22 PM
Young Gun
kc_matt's Avatar
Good Christ! That is awesome!
1990 VN 750
First (hopefully last) time in the shop:
Carb rebuild New brakes front and back New radiator fan
I've done:
Spline Lube New (used - non-leaky) Gas Tank New Fork Seals New Pirelli tires New Yuasa Maintenance Free Battery
Fresh Dexcool coolant Upgraded Shunt-type R/R (Relocated) Headlight Bypass Stator tested - PASSED
Clutch Swap - EBC Street Racer Frictions with new eBayed steels ACCT to MCCT conversion
kc_matt is offline
post #5 of 26 (permalink) Old 06-18-2011, 08:51 PM
electrum's Avatar
you are going to use an independent rear end? i think all the trikes i have seen use a solid axle.
96 Vulcan 750
electrum is offline
post #6 of 26 (permalink) Old 06-18-2011, 09:48 PM Thread Starter
wanted something different and a challenge
plus i wanted the ride characteristics of the independent suspension
post #7 of 26 (permalink) Old 06-18-2011, 10:20 PM
electrum's Avatar
not having done it, this is just a guess on my part.. but i would think when you turn you are going to lean to the outside of the turn with an independent suspension. doesn't sound like that would be comfortable or safe. i'd research that a lot before i spend a lot of time on it.
just my 2cents.. and probably only worth it
96 Vulcan 750
electrum is offline
post #8 of 26 (permalink) Old 06-19-2011, 09:42 AM
Awesome.
km60155 is offline
post #9 of 26 (permalink) Old 06-19-2011, 10:21 AM Thread Starter
To fix the roll im going to be running a custom sway bar but with the air shocks its not to bad for me but my mother in law it will be already planned for that issues
post #10 of 26 (permalink) Old 06-19-2011, 12:35 PM
wolflrv's Avatar
That's a helluva way to take out your mother-in-law!! Just kidding!! Looks awesome!!
New rider/mechanic of '85 VN700 Vulcan. (25k miles)
Link to bike restoration blog:
http://trailofthewolf.blogspot.com/s...%20Restoration
wolflrv is offline
