Blown head gasket - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 06-15-2011, 10:30 AM Thread Starter
stereopath's Avatar
Angry Blown head gasket
My bike is overheating. Has coolant, oil but over heats bad. Could this be a blown head gasket? What r the symptoms of a blow head gasket and process changing?
Video I shot and edited of my 1985 Vulcan VN750
mounted iphone gps for speedo and milage
custom seat mod
stator replaced
mosfet r/r
gauges and dash removed
baffles drilled
synth oil
ear shave
de goat
412 progressive 11" shocks
Custom paint
NGK Iridium Spark Plugs
cam chain tightened
Coming soon:
spline lube
whitewall tires
stereopath is offline
post #2 of 15 (permalink) Old 06-15-2011, 10:37 AM
JM2001's Avatar
How about a stuck thermostat?
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 15 (permalink) Old 06-15-2011, 10:46 AM
Easily checked, just pull it and ride... If it runs cool, install a new thermostat, but check it in heated water before installing...
post #4 of 15 (permalink) Old 06-15-2011, 10:48 AM Thread Starter
stereopath's Avatar
Thermostat
Doesn't the thermostat just control the fan? My fan is manual.
custom seat mod
stator replaced
mosfet r/r
baffles drilled
synth oil
ear shave
de goat
Custom paint
cam chain tightened
Coming soon:
spline lube
whitewall tires
post #5 of 15 (permalink) Old 06-15-2011, 11:30 AM
JM2001's Avatar
Are you blowing smoke ( white ) out your azz ( exhaust pipes ? ) LOL Are you leaking antifreeze near the top of the engine? If no, it's probably not a head gasket problem. Most Vulcans I have seen have electric fans. Where is your hand crank to turn the fan manually ? LOL
Seriously, I would check the thermostat and also check to see if your radiator needs flushing and cleaning. Make sure you are using a 50/50 mix of coolant.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 15 (permalink) Old 06-15-2011, 12:04 PM
Crobins365's Avatar
Fan switch is a likely culprit - you can put on a manual one pretty easily ( I may have a spare switch sitting around, but would have to check). Also, if you changed the oil recently, you may have a bubble in there and need to "burp" the system.
C
Crobins365 is offline
post #7 of 15 (permalink) Old 06-15-2011, 12:05 PM
The wire attached to the thermostat housing controls the temp gauge on the dash.
The cooling fan switch is located at the bottom left side of the radiator.
post #8 of 15 (permalink) Old 06-15-2011, 12:30 PM
abyssdncr's Avatar
Compression check should help you identify a headgasket issue, looks like the others have you covered nicely on the thermostat issues.
'98 VN750, Mustang Seat, F&S Engine Guards, Highway pegs, Pro-Tac backrest, Harley 58121-85B windshield lowers, Autometer 3391 voltmeter, ACCT to MCCT, pickup coils at 0.020", Coasters, National Cycle N2220, Vista Cruise Universal, Single Filter Ear Shave, Givi Monokey Sidebag Mounts, Givi E21 side bags, Knifemaker style turn signal relocation, helmet locks relocated.
abyssdncr is offline
post #9 of 15 (permalink) Old 06-15-2011, 12:41 PM
Roach's Avatar
No, the thermostat is a mechanical valve that controls coolant flow. It's designed to open at a certain temperature. If it does not open at this temp. your liable to have the issues stated.
How a Thermostat Works
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #10 of 15 (permalink) Old 06-15-2011, 12:48 PM Thread Starter
stereopath's Avatar
No leaky coolant, or white smoke.
custom seat mod
stator replaced
mosfet r/r
baffles drilled
synth oil
ear shave
de goat
Custom paint
cam chain tightened
Coming soon:
spline lube
whitewall tires
