Speedo, tach and dash needs to go!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 24 (permalink) Old 06-14-2011, 10:28 PM Thread Starter
stereopath's Avatar
Cool Speedo, tach and dash needs to go!!!
Has anyone ever taken the speedo/tach/dash off of a Vulcan? Looks 100% better! Want to do this but have a couple problems.
1. Headlight won't work without dash.
2. Still need speedo by law.
3. Fuel gauge is a good thing.
Any solutions or after market ideas out there? Ill post how my bike looks without them shortly. I know u will want to do the same when u see it!
stereopath is offline
post #2 of 24 (permalink) Old 06-14-2011, 10:39 PM
Concert connoisseur
wib714's Avatar
1. I'm sure you could wire it direct with a toggle somehow!
2. G.P.S.?
3. fill up at 120-130 miles
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #3 of 24 (permalink) Old 06-15-2011, 12:15 AM Thread Starter
stereopath's Avatar
Gps
Not sure what u mean by GPS???
post #4 of 24 (permalink) Old 06-15-2011, 12:29 AM
Global positioning system....
I have taken the dashboard off my 750 and I put all the extra wire in the headlight housing.... I still use the same speedo but everything works just fine, I dont have any issues
biggestjd is offline
post #5 of 24 (permalink) Old 06-15-2011, 12:49 AM Thread Starter
stereopath's Avatar
I know what gps is but how will that take the place of a speedo?
post #6 of 24 (permalink) Old 06-15-2011, 01:01 AM
Patriot Guard Rider
The DEUCE's Avatar
Use the Speedo App on your cell phone.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #7 of 24 (permalink) Old 06-15-2011, 01:03 AM
Sorr.... GPS devices give you speed on the display
post #8 of 24 (permalink) Old 06-15-2011, 01:17 AM Thread Starter
stereopath's Avatar
How r u using the speedo without dash? Any pics? Tell me more!
post #9 of 24 (permalink) Old 06-15-2011, 01:30 AM
You can build a bracket for the speedo and bolt it to the triple tree or anywhere you have a bolt. If you take the screw off the back side of the speedometer, you will see how the stock one is on there, you just need to take that nut off, and use piece of strap metal, drill a couple holes and bend the metal to your liking....
Thats not very in depth but Ill get you a picture or two in the next couple days
post #10 of 24 (permalink) Old 06-15-2011, 02:14 AM Thread Starter
stereopath's Avatar
ok cool! Sounds good! I also found a speedo app for my iphone 4. Seems to work perfect. Just got to mount it some way. Maybe I keep the tach instead and use the iphone for speed. Now what about the fuel gauge...mmm ride till it sputters, hit reserve and head to the gas station?!! haha
Tags
aftermarket gauges , dash , remove , speedo , tach
