Clear vent hose - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-12-2011, 12:34 AM Thread Starter
Thumbs down Clear vent hose
2004 with 9000 miles.
I was in the process of trouble shooting another problem (another thread).
Took the bike for a text drive.
It ran great.
Upon inspection, I found a piece of clear vent tubing, almost dragging the ground.
It looked like it had been melted off.
The other end is probably up there somewhere?
It was too dark to look around.
I'll check it out, tomorrow.
Did I knock something off, when looking for the other problem?
I appreciate all the help that I have received from this forum.
The 750 is a completely different beast from my Buell Blast (previous bike).
Thank you
daffy is offline
post #2 of 10 (permalink) Old 06-12-2011, 12:41 AM
Patriot Guard Rider
The DEUCE's Avatar
Was it a skinny clear hose? If so, it is probably the vent hose on your acid battery.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 10 (permalink) Old 06-12-2011, 02:17 AM
Originally Posted by the deuce View Post
was it a skinny clear hose? If so, it is probably the vent hose on your acid battery.
x2^^^
post #4 of 10 (permalink) Old 06-12-2011, 09:05 AM
x3^^^ Yep, acid eats up the black rubber hoses...
post #5 of 10 (permalink) Old 06-12-2011, 09:12 AM
Crobins365's Avatar
Could also be the overflow hose for the cooling system if it was black and opaque. Not life-threatening to your bike - just replace it when you can (assuming there's still some hose up there!).
C
Crobins365 is offline
post #6 of 10 (permalink) Old 06-12-2011, 12:53 PM Thread Starter
Thumbs down
Wow, thanks for the help.
That make me feel better.
It was clear and skinny, so sound like the battery.
How long does it need to be?
Best place to get a replacement?
What type of material?
This forum has been so much help.
Thank you, all.
daffy is offline
post #7 of 10 (permalink) Old 06-12-2011, 01:25 PM
Don't replace the hose, replace the battery with a maintenance free, sealed AGM battery, that doesn't require a vent hose.
This battery type will save you all kinds of grief. Search the forums, the Deka battery is a popular, low cost AGM.
km60155 is offline
post #8 of 10 (permalink) Old 06-12-2011, 02:12 PM
You can pick up similar good quality batteries locally, but this is a good one at a fair price:
http://cgi.ebay.com/ebaymotors/Deka-...item3eee173adb
post #9 of 10 (permalink) Old 06-12-2011, 07:43 PM
Concert connoisseur
wib714's Avatar
the hose is a cheap replacement but the battery will save you tons in the long run. x3 on replacing the battery!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #10 of 10 (permalink) Old 06-12-2011, 09:49 PM Thread Starter
Thanks, I will put that on top of the shopping list.
daffy is offline
