Poogs?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 06-07-2011, 07:45 PM Thread Starter
Thumbs down Poogs??
I am a newbie, to this forum. Have been trying to learn what I can from it. I purchased my '04 750, this March. I changed all the fluids and had new tires put on. Here's my question - can POOGS happen with 3/4 tank of gas? Background: Bike ran great to work, this morning. Left work, this afternoon. Bike started fine. Sat through two stop lights, then hit the highway. It started to lose power. I headed toward the shoulder, when the power came back. It lasted a mile then died. I didn't know about taking the gas cap off, until now. Had it towed home. Tried starting it. At first it wouldn't start, then it finally did. Temp gauge was normal. Temp outside was 95. Also, problem seem to start after some strong wind gust. Might be just a coincidence. Total time 7 minutes, maybe 5 miles, at the most.
Where would you start the troubleshooting?
daffy is offline
post #2 of 11 (permalink) Old 06-07-2011, 08:40 PM
Poogs is a caused by vacuum in the fuel tank due to the vent hose or valve becoming plugged.
If your tank vent was plugged in 95*F temps, the tank would be pressured up before riding IMHO. Riding for only 5 miles or 7 minutes would not drain enough fuel from the tank fuel from the tank to create a vacuum condition. The tank being 3/4 full also sound like it is not POOGS to me.
You could test fuel flow by taking both fuel lines and vacuum line from the carb, then drain gas into clear bottles while sucking on the vacuum line. See how much gas will drain before the flow slows or ceases. Just an idea to try.
post #3 of 11 (permalink) Old 06-07-2011, 09:32 PM
Sounds more like the carb vent hose to me........ Check for the tube behind the right ear and make sure it is intact and not bottomed out in the ear.
dariv is offline
post #4 of 11 (permalink) Old 06-07-2011, 11:33 PM
X2 dariv. Good call.
The wind gust makes sense too, if the vent hose is pulled out and exposed to high speed air passing over an exposed end.
Here is where it should be.
https://www.vn750.com/photopost/showp...o=1757&cat=503
daffy, cut the end of the hose off at a 45* angle before pushing it back in the right ear.
post #5 of 11 (permalink) Old 06-08-2011, 09:11 AM
Member? ... check.
ZCraggRatt's Avatar
I've been thinking about this simple instruction we give to eliminate bottoming out the carb vent hose. Correct me if I'm wrong, but the 45 degree angle cut would only be effective if the cut is aligned with the slot in the ear clamp, right? If the cut is placed opposite the slot, and the hose bottoms out, venting is still obstructed right?
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine
Done: Coastered, .020 ign., Iridiums, VM
Plexistar II, MCCT's, Relocated MOSFET
Next: LED's
Will Do: Horns, Shave(maybe)
ZCraggRatt is offline
post #6 of 11 (permalink) Old 06-08-2011, 04:45 PM
Yes, the cut angle needs to face the slot if the hose gets pushed to the bottom.
post #7 of 11 (permalink) Old 06-11-2011, 04:53 PM Thread Starter
Thumbs down
Thank you for all the advise.
The hose had come off the right ear.
I cut it at a 45 degree angle, pushed it back in.
Checked all the other vent hoses.
Everything looked fine.
Went ahead and put in new plugs, since I didn't know how old these were.
Also checked the gas tank hose.
Took it for a test drive and it ran fine.
Got it home and noticed the hose had came off the right ear again?
I think that I got it in there good, this time and will take it for a test drive, later tonight.
It does go in the spot that has a slit cut in the bottom, right?
daffy is offline
post #8 of 11 (permalink) Old 06-12-2011, 12:31 AM
Yes.
post #9 of 11 (permalink) Old 06-12-2011, 10:15 AM
clock152's Avatar
if it still wont stay in there you could try a few other things but I would buy a filter to put on it and run it under the seat. EMGO is what I have on mine but I am shaved... some have had good results by running the hose under the tank and connecting it to the nipple from the sending unit. others have ran it into the frame of the bike... as long as it is not getting to much air flow or botteming out your good to go.
clock152 is offline
post #10 of 11 (permalink) Old 06-12-2011, 09:24 PM
The only thing that's ever worked for me is to switch to reserve and then fill up with gas as soon as I can. I also try to not park in the sun when below half tank and it's really hot out.
accord_guy is offline
