Rides Great Except for - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-06-2011, 03:05 PM Thread Starter
OldBikeNewRider's Avatar
When I get in stop and go traffic my bike likes to die. Not sure why? The thing runs and starts great just this one issue. I figured I check the vacuum hoses first. Looking for some suggestions. Thanks!
1986 VN 750
20,000 miles
Replaced Stock Turn signals
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
OldBikeNewRider is offline
post #2 of 10 (permalink) Old 06-06-2011, 03:12 PM
Vacuum leak... a good place to start, or Try Seafoam in Fuel tank. Stop n' Go traffic...heat issues ?? Hows your fluid levels ?
post #3 of 10 (permalink) Old 06-06-2011, 06:52 PM
whats your idle speedset at?
post #4 of 10 (permalink) Old 06-06-2011, 11:36 PM Thread Starter
Idle speed is 1100-1200
1986 VN 750
20,000 miles
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
post #5 of 10 (permalink) Old 06-06-2011, 11:59 PM
Well, if your battery is charging properly, and the bike is dying in stop and go traffic, but not at stops spaced further apart ... Then it sounds like a heat issue or a jetting problem.
Have you adjusted your fuel/air screws? Have you installed iridium plugs?
If your idle circuit is running a bit rich, it might be fouling your plugs at low rpm running from the slow traffic environment .
Or your charging system is not running efficiently due to higher temps and low rpms.
Have you relocated your R/R? Running regular gas?
post #6 of 10 (permalink) Old 06-07-2011, 12:03 AM
peerless's Avatar
Does it die early on in a ride during stop and go traffic or only after heating up a bit? Does it die when sitting still (in the driveway or garage) while simulating stop and go (revving and releasing)? These answers could help us help you determine if it is an overheating or carb issue.
2004 VN750 "Rosanna"
Acquired March 6, 2010
Done:
NGK Iridium Plugs
NGK Caps
Big Crank ETX15L AGM Battery
Battery Tender Jr. w/Pigtail
Rear Spline Lubed
Front Spine/U-Joint Lubed
Metzeler ME 880's
Brake Fluid Flushed, Filled, and Bled
Saddlemen Studded Saddlebags and Tank Bib
Installed 12 Volt Power Outlet
Debaffled
R/R Relocated flightcontrol Style
Pending
N/A... I'm Going Ridin'
peerless is offline
post #7 of 10 (permalink) Old 06-07-2011, 12:27 AM Thread Starter
It dies after heating up and it's more of an issue on hot days. Ok I had to edit this, things got away from me here hunting and pecking. Not sure what plugs are in the bike but I have iridium plugs to put in. Haven't done it yet. I do use regular gas and usually add a shot or two of seafoam.
1986 VN 750
20,000 miles
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
post #8 of 10 (permalink) Old 06-07-2011, 12:40 AM
peerless's Avatar
It dies after heating up and it's more of an issue on hot days. N I have the iridirunning on regular gas.
Does it restart right away?
Done:
NGK Iridium Plugs
NGK Caps
Rear Spline Lubed
Metzeler ME 880's
Debaffled
Pending
peerless is offline
post #9 of 10 (permalink) Old 06-07-2011, 10:22 AM Thread Starter
It will restart right away but I either have to go full throttle or use choke.
1986 VN 750
20,000 miles
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
post #10 of 10 (permalink) Old 06-07-2011, 10:34 AM
fergy's Avatar
Air filters in good shape? If you tend to have to choke it or better words, enrich the mix to get it to start when hot, it sounds like too much air getting in, i.e. vacuum leaks or filters ripped up... Just fishing for info...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
