bike conking out while riding - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-06-2011, 03:01 PM Thread Starter
UnderMind's Avatar
Twice now I've had my bike essentially just turn off while riding. Today it acted as if it had run out of gas even though there was about a 1/4 tank left. Has anyone else had this issue?
The bike is a 94 and is pretty much stock. I'm wondering if I have a fuel flow problem. Initially it didn't want to start again, but I put the choke on full (even though the bike was well warmed up) and it started reluctantly. It ran fine after that.
UnderMind is offline
post #2 of 7 (permalink) Old 06-06-2011, 03:17 PM
Smile
I have a friend who had similar issues with his 1100 or 1200 ?.... turned out he was low on Oil ! Added oil....Problem went away ! Also, clutch often gets grabby when low on oil.
post #3 of 7 (permalink) Old 06-06-2011, 03:32 PM
Member? ... check.
ZCraggRatt's Avatar
Sounds like POOGS. Check out this thread:
https://www.vn750.com/forum/showthread.php?t=17572
~~C8> Ratt
________________________
'91 VN750 - Cosmic Splendor/Candy Wine
Done: Coastered, .020 ign., Iridiums, VM
Plexistar II, MCCT's, Relocated MOSFET
Next: LED's
Will Do: Horns, Shave(maybe)
ZCraggRatt is offline
post #4 of 7 (permalink) Old 06-06-2011, 03:36 PM
clock152's Avatar
ignition switch sounds like to me.. if it is just shutting off then that is the place I would look.. and then go to your safty switches (clutch, nutral and kickstand switch).. check and clean all of your ground points thruout the bike.
clock152 is offline
post #5 of 7 (permalink) Old 06-06-2011, 09:43 PM
Crobins365's Avatar
Does sound a lot like POOGS -the thread Ratt's pointing you to is a really nice write-up with very clear instructions on how to clean the vent hose and cap. Good idea to go through those steps. It could also be a gummed up carb, though. When was the last time you cleaned 'em?
C
Crobins365 is offline
post #6 of 7 (permalink) Old 06-06-2011, 10:15 PM
Ceal's Avatar
Have you tried switching to reserve when it happens? Does it behave differently in reserve?
Ceal is offline
post #7 of 7 (permalink) Old 06-07-2011, 12:13 AM
peerless's Avatar
Exactly what I'm thinking. Make sure the vent hose that goes into the right ear is actually there and is not bottomed out or kinked.
2004 VN750 "Rosanna"
Acquired March 6, 2010
Done:
NGK Iridium Plugs
NGK Caps
Big Crank ETX15L AGM Battery
Battery Tender Jr. w/Pigtail
Rear Spline Lubed
Front Spine/U-Joint Lubed
Metzeler ME 880's
Brake Fluid Flushed, Filled, and Bled
Saddlemen Studded Saddlebags and Tank Bib
Installed 12 Volt Power Outlet
Debaffled
R/R Relocated flightcontrol Style
Pending
N/A... I'm Going Ridin'
peerless is offline
