Finish peeling on speedometer and other readings... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 05-23-2011, 12:44 PM Thread Starter
Guess this is a common problem. The metallic (plastic-ey) finish on my speedometer, voltometer, etc is peeling. I've seen a few pictures of bikes with these painted black. What's the procedure? I'm not against sanding them down and using plain old black rustoleum. Cheap is my specialty.
vulcanpower is offline
post #2 of 9 (permalink) Old 05-23-2011, 01:57 PM
clock152's Avatar
Yup.. that is the procedure.
clock152 is offline
post #3 of 9 (permalink) Old 05-23-2011, 02:40 PM
Here is a link with a little info on painting the gauge trim.
https://www.vn750.com/forum/showthrea...speedo%2Brings
There is an old thread with a complete write-up and pics, but I can`t find it now.
The best results will be obtained by taping the main part of the gauge off from the trim rings. Prying the rings off will end up with "ripples" when it is reinstalled.
I recall someone mentioning to use a flat black paint to cut down on glare that is common from the polished trim rings.
post #4 of 9 (permalink) Old 05-23-2011, 03:46 PM
wolflrv's Avatar
I think this is the thread you're looking for...this is what I plan to do to mine too.
https://www.vn750.com/forum/showthrea...ing+gauge+trim
New rider/mechanic of '85 VN700 Vulcan. (25k miles)
Link to bike restoration blog:
http://trailofthewolf.blogspot.com/s...%20Restoration
wolflrv is offline
post #5 of 9 (permalink) Old 05-23-2011, 07:56 PM
Thanks wolf. That thread shows the finished product off very well.
There was an even earlier thread that showed the work in progress, taping etc.
Ha- found it: https://www.vn750.com/forum/showthread.php?t=8047
post #6 of 9 (permalink) Old 05-24-2011, 01:59 AM
I use some of my gun cleaners to get rid of almost all of the surface rust that was on my gauges. I think one more time with some fine steel wool will just about do the trick. I was going to paint mine silver if that didn't work out, just curious why I see a lot of people using black? It kinda makes the gauges stick out like a sore thumb to me.
post #7 of 9 (permalink) Old 05-24-2011, 10:35 AM
flitecontrol's Avatar
Shark, I agree with you.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is online now
post #8 of 9 (permalink) Old 05-24-2011, 11:35 AM
post #9 of 9 (permalink) Old 05-24-2011, 11:53 PM
baldy's Avatar
I used aluminum foil. Using it like steel wool, it takes the rust off and puts the flat silver color back. Did it to my 93' 8 years ago and just now starting to need to do it again.
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
baldy is offline
