Spark Plug Socket - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 27 (permalink) Old 04-30-2011, 08:20 PM Thread Starter
Angry Spark Plug Socket
What size socket is required to remove spark plugs? Also, engine will not turn over. Any ideas as to problen/solution? I have a fully charged battery.
jack smith is offline
post #2 of 27 (permalink) Old 04-30-2011, 08:24 PM
Git-R-Done!
AZ Kev's Avatar
Hi Jack,
Sorry about your starting problem. The socket is an 18mm - and I can verify that, because I picked one up yesterday to change my plugs (I'm having an issue keeping my running AFTER it's started).
As far as that goes, and forgive me if I am patronizing, but the red "Run" switch on the right handlebar didn't get flipped to 'Off' did it? That has even gotten me a time or 2.
Good luck : )
AZ Kev
Arizona Kev
1989 VN750
7800 orig mi when purchased Jan 2011
Turned 11,000 mi Nov 2011
Saddlebags
Taillight relocation kit
Chad's highway peg mounts
Emgo Pegs
Aftermarket mirrors
Dunlop D404's
Otherwise, all stock
"But it's a dry heat - like the inside of an oven"
AZ Kev is offline
post #3 of 27 (permalink) Old 04-30-2011, 08:35 PM
X2 -It is an 18 mm plug wrench.
Does the relay/solenoid click?
Starter tries but engine is seized?
Or do you get no response at all when the start button is pushed?
post #4 of 27 (permalink) Old 04-30-2011, 09:28 PM
KidChaos's Avatar
Just a note, I heard craftsman 18mm deepwell socket fits well, others work, but not all. I had a duralast 18mm Deepwell and it was too wide at the tip. Had to use a lathe to remove about 1mm in diameter around the end of the socket for it to fit down in the recessed plug ports around the socket.
KidChaos is offline
post #5 of 27 (permalink) Old 04-30-2011, 11:18 PM
clock152's Avatar
is it a fully charged AGM battery?
clock152 is offline
post #6 of 27 (permalink) Old 04-30-2011, 11:22 PM
and you heard correctly
post #7 of 27 (permalink) Old 04-30-2011, 11:23 PM Thread Starter
I do not have any response when the start button is pushed. The turn signals work but the headlight lamp will not come on manually.
Thanks for the information regarding the socket size.
post #8 of 27 (permalink) Old 05-01-2011, 12:33 AM
Warlord247's Avatar
You might try to wiggle the ig switch. the contacts may be worn. have this problem with my mistress, and she can be cantankerous with this problem.
"The Mistress".
1985 VN700A1
MODS:
New stator
My version of the Marbleing
New paint and trim
New oversized front tire
Degoated
Iridium Plugs
New grip and lever covers
New(er) Ignition switch
Waiting on:
A good ride
As always:
Wanting attention at all times.
Why should I act my age, I am an ADULT!!!!!!
Warlord247 is offline
post #9 of 27 (permalink) Old 05-01-2011, 02:15 AM
LOL; what Denny said. Also, the 18mm deep socket from Autozone will work, unless they changed brands recently.
J.D.
Kerrville, TX
'95 Vulcan 750 "Therapy II",
aka "Raggedy Ann"
'95 VN750 project
'03 VN800B "The Little Black"
'04 VN800E Drifter project
'93 VN1500A custom project
VROC #16185
GCVROC #33
J.D. is offline
post #10 of 27 (permalink) Old 05-01-2011, 11:48 AM
Patriot Guard Rider
The DEUCE's Avatar
I purchased a Master Mechanic 18mm Deep Socket from Ace Hardware which worked. FYI, Crescent socket did not.
VN750 #9300 & VROC #33453
The DEUCE is offline
