Goggles/ face mask fog up quick - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-25-2011, 11:42 PM Thread Starter
For some reason if I wear my full face helmet or my goggles; they fog up pretty quick when I'm not riding at high speed. If my son puts them on he doesn't have this problem. Do my eyes just make more moisture? With my full face mask the vent doesn't help at all. The only thing that helps is to keep it part way open. Is it just me??
RobertGary1 is offline
post #2 of 6 (permalink) Old 04-25-2011, 11:54 PM
bigbluezuk's Avatar
You just sweat more. Your cooling system is better than your sons.
Somebody else will chime in with anti fog stuff, my fullface has an anti-fog insert that has so far worked 100%.
1995 VN750 - 10K
bigbluezuk is offline
post #3 of 6 (permalink) Old 04-26-2011, 01:16 AM
'03 VN750 "Rosie"
bstew7890's Avatar
It's not you, my helmet does the same thing in colder weather. I picked up an anti fog spray that helps.
'03 VN750 "Rosie"
Purchased in June 15, 2010
Lubed Splines
Lubed and Adjusted Clutch Cable, Throttle Cables.
Relocated Voltage Regulator
Brakes Bled
Luggage Rack
Lazy Rider Bag
Leather Saddle Bags
Legitimate Title!! (finally!) Aug 30, 2010
New AGM Interstate Battery Sept 15, 2012
2008 Hyosung GV250 (sold!)
bstew7890 is offline
post #4 of 6 (permalink) Old 04-26-2011, 07:16 AM
Mine fogs a bit at low speeds or stopped even with the vent open, but the shield on this one has a very close first notch that works fine... On others that I've had the first notch on the shield opened too far and I kept a small coated chip bag clamp to put on the bottom of the shield to give a small (+/-1/16") opening... Haven't used any of the anti-fog stuff though, as most of my ridin is in the warmer weather periods...
post #5 of 6 (permalink) Old 04-26-2011, 08:01 PM
Concert connoisseur
wib714's Avatar
mine fogs up really bad everytime I almost hit a deer! I do too at slower speeds though, have to crack mne a bit till I get moving.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #6 of 6 (permalink) Old 04-26-2011, 08:50 PM
http://www.pinlockusa.net/
Solves the problem. Period.
