Removing stickers on gas tank - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-25-2011, 08:46 PM Thread Starter
Hello again,
I'm trying to remove a sticker of a nude woman from the tank of my bike left there from the previous owner. Not a terrible picture, just not my style or a proper place for it.
What is the best way for removing such things without damaging the paint?
So far I've just markered it over so my little sister doesn't see it.
Thanks!
Paradigm is offline
post #2 of 6 (permalink) Old 04-25-2011, 09:24 PM
I've heard of using a hair drier or heat gun to loosen the glue and gently scrape off
cdaddy is offline
post #3 of 6 (permalink) Old 04-25-2011, 09:57 PM
Noob.
You could try to use the hair dryer to heat it like cdaddy said, with a piece of thin string, like fishing line or something to get under the sticker and swork it through sticker. You'll more than likely have goo on the tank afterwards, but it'll come off with some washing and wiping.
ClassicFnAllen is offline
post #4 of 6 (permalink) Old 04-26-2011, 12:47 AM Thread Starter
Will "Goo Gone" do any damage? That stuff works great, just don't want to mess it up, you know the deal.
Paradigm is offline
post #5 of 6 (permalink) Old 04-26-2011, 04:16 AM
Goo Gone should work. Try it on the underside of the tank in a hidden spot where it won't be seen. It has Xylene in it which might streak the paint if it's older or faded.
If the paint is good, it won't affect it any.
If you use a heatgun and have any glue on the tank, WD40 and rubbing alcohol works great for removing it, but not at the same time.
RakerBill is offline
post #6 of 6 (permalink) Old 04-26-2011, 06:14 AM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
Fingernail Polish Remover works better then Alcohol
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
