how to fix a loose tach/speed??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-18-2011, 03:21 AM Thread Starter
scuba's Avatar
I have searched older posts and havent found any information on how to tighten the tach. On the back of the tach the screw is in all the way and tight. But that thing wobbles like crazy. any easy fixes???
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
post #2 of 8 (permalink) Old 04-18-2011, 08:23 AM
Patriot Guard Rider
The DEUCE's Avatar
My tach does the same thing. I just haven't made the time to pull it apart and figure out how to tighten it down.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 8 (permalink) Old 04-18-2011, 08:52 AM
put a nylon washer under said nut... get the washer from radio shack. worked like a charm on mine.
post #4 of 8 (permalink) Old 04-18-2011, 09:02 AM
JM2001's Avatar
I put a piece of 1/2 inch clear plastic tubing about 3 inches long sliced down the middle and wedged it over the bracket and into the hole on the tack. No vibration whatsoever and you don't notice the tubing.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 8 (permalink) Old 04-18-2011, 09:28 AM
The screw at the back only holds the cover on... It has nothing to do with how the tach is mounted to the bike.
However, you can take a thin piece of metal and build a "bridge" between the tach and the speedo....by using those bottom screws.
Just make it as wide as the distance between each opposite side of the gauges and mark the spot where each screw is located. Drill a hole for each.... Don't use too thick of a piece of metal or you'll have to find longer screws.
This will tie the two gauges together and help dampen out the shaking.
I think Diana may have a photo of how she made hers like this.
post #6 of 8 (permalink) Old 04-18-2011, 11:29 AM
I wrote a reply earlier but hit the wrong key and didn't post...lol...
Anyway, what KM said, but keep in mind that some of the shake it to protect the inards of the tach. from the strong vibes..
post #7 of 8 (permalink) Old 04-18-2011, 02:00 PM
heres what I did to both the speedo and tach when I replaced bulbs with LED's , took a 2in piece of 1/4 fuel line cut that in half "lengthwise" un bolted the bracket and placed both halfs on on top of and one below the bolts put bracket back on tighten down snug so you will be squishing the fuel line..... I did this to both sides and now both are SOLID even on the bumpy gravel county rode I live on
qweesy is offline
post #8 of 8 (permalink) Old 04-18-2011, 03:48 PM Thread Starter
scuba's Avatar
well today I got gutsy. I am not very mechanical what so ever. So I take the tach/speed cluster off the bike by taking off the two bolts. I then took the screw off of the back of the tach (that holds the chrome back on). Took off two screws in the back of the cluster. Took one bolt off of the mounting piece for the tach, and slid the chrome piece down. Noticed the nuts were barely on. Looked at the speed mount side noticed there was washers on the back of the nuts. I simply put two washers on the tach side. And tightened the speed nuts on the speedometer side which were laso a little loose. Put it all together and tested the firmness by hitting as many bumps as i could. Nothing moved. The whole process took about ten minutes. No I didn't take pictures because I just wanted to get it done.
vn750.com scuba
1984 kz750 ltd
2002 nomad trike
1978 suzuki 250
1964 harley amf
custom exhaust
custom mirrors
custom grips
custom floorboards
custom exhaust
scuba is offline
