Throttle is now operable - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 04-04-2011, 09:48 PM Thread Starter
Wareagle1970
carolesteven's Avatar
But, I am still having the same issue where I have to manually let off the accelerator... I sprayed a crap load of
PB Blaster on the wheel on the carb, and worked the throttle a ton, but it is still doing it...
Any suggestions??
2003 VN750 de-goated
Kuryakyn ISO Grips
Kuryakyn LED Voltmeter
coastered
Slipstreamer Hellfire windshield
Shindengen Mosfet R/R
Kawasaki Engine Guard
Fire & Steel Footpegs
Need Knifemaker to make me a seat like his
Hickory, NC
carolesteven is offline
post #2 of 13 (permalink) Old 04-04-2011, 09:54 PM
Is the return spring properly installed??? It should be between the carbs.
post #3 of 13 (permalink) Old 04-04-2011, 09:56 PM Thread Starter
Wareagle1970
I haven't touched the return spring
Kuryakyn ISO Grips
coastered
Hickory, NC
post #4 of 13 (permalink) Old 04-04-2011, 10:04 PM
Have you greased the cables?
post #5 of 13 (permalink) Old 04-04-2011, 10:06 PM Thread Starter
Wareagle1970
I lubed them using Knifemaker's recommendation. That was when I broke my throttle sleeve.
Kuryakyn ISO Grips
coastered
Hickory, NC
post #6 of 13 (permalink) Old 04-04-2011, 10:08 PM
Your not getting the cables too tight are ya???
post #7 of 13 (permalink) Old 04-04-2011, 10:12 PM Thread Starter
Wareagle1970
not sure. How can you tell?
Kuryakyn ISO Grips
coastered
Hickory, NC
post #8 of 13 (permalink) Old 04-04-2011, 10:40 PM
You should have a little bit of looseness to the cables to keep the sleeve from getting tight against one side.
post #9 of 13 (permalink) Old 04-04-2011, 10:49 PM
clock152's Avatar
if the pull cable dosnt spring back when you take your hand off of the gas then its too tight.... the push cable is basicaly a saftey.
clock152 is offline
post #10 of 13 (permalink) Old 04-05-2011, 08:49 AM Thread Starter
Wareagle1970
Okay, so I need to loosed the pull cable some. From memory, that is the one furthest from you as you are sitting on the bike.
Kuryakyn ISO Grips
coastered
Hickory, NC
