85 vn700 TANK question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 04-02-2011, 05:55 PM Thread Starter
are there any smaller tanks that fits on vn700?
uhhitsfuzzy is offline
post #2 of 7 (permalink) Old 04-02-2011, 09:11 PM
WHY? Most of us are looking for more range, not less.
post #3 of 7 (permalink) Old 04-03-2011, 12:25 AM Thread Starter
Its coz I want to use the clubman handle bars and its not clearing with the tank. Unless I hammer bith sides of the tank and I can't make full turns.
I know I know... Why clubman? I just like the way it looks
post #4 of 7 (permalink) Old 04-03-2011, 12:56 AM
OK, now I understand. You must be young and thin to be able to ride leaned over that far!
I wonder if a peanut tank off a Sportster could be made to fit?
post #5 of 7 (permalink) Old 04-03-2011, 01:29 PM Thread Starter
I could lean it but its just not clearing it. I barely started riding tho. Btw now I have another problem... the throttle push won't retract coz I broke a tiny piece of plastic that holds the end of the cable. Any ideas on this?
post #6 of 7 (permalink) Old 04-03-2011, 02:05 PM
clock152's Avatar
if your spring is good you don't need the push cable only the pull.
also.. have you thought about useing 2 inch risers on those bars?
clock152 is offline
post #7 of 7 (permalink) Old 04-03-2011, 06:29 PM Thread Starter
it worked!! thank you! i kinna dont like the riser look. i just gotta figure out a way to find a smaller tank. if not ill switch to convertibars.
