a few questions. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-30-2011, 11:12 PM Thread Starter
a few questions.
I was reading through a list of things I should do once I get my bike and definately plan on such.
Going to buy an AGM battery right away and also read about relocating some electrical stuff from the goats belly area to somewhere else, perhaps someone knows of a step by step guide someone might have done? I also read about buying a voltmeter and hooking that up to monitor things, what is the purpose of this, is there certain things to look for that if you catch early with it will save you some trouble or...?
Thanks,
Unclemoney.
Unclemoney is offline
post #2 of 12 (permalink) Old 03-30-2011, 11:31 PM
clock152's Avatar
clock152 is offline
post #3 of 12 (permalink) Old 03-30-2011, 11:51 PM
The AGM battery is a good move. The other stuff is not critical.....relocating the R/R has actualy never been proven to be necessary...but most agree it sounds like a good idea. I never moved mine and never had a problem.
A voltmeter is a good idea too...but makes more sense if you plan on adding any electrical accessories... Like heated gear, or extra lighting.
A few things you should do.... Make sure the rear drive splines are lubed well, silicone the swing arm caps and the threads on the toolbox lock....these are notorious for falling off.
post #4 of 12 (permalink) Old 03-31-2011, 06:22 AM Thread Starter
I'll be purchasing her from the dealer this upcoming week, we already have a price set. Should I contact them and ask them to do such? Either way whether they say yes or no I'll make sure to do this myself as you never really know what they may or may not do.
Thanks for the input guys!
post #5 of 12 (permalink) Old 03-31-2011, 12:21 PM
flitecontrol's Avatar
The voltmeter will give you early warning about charging problems, possibly saving a towing bill.
DO NOT trust the dealer to lube the splines. Most have no idea it needs to be done or how to do it and few have the proper lubricant (Honda Moly 60 or equivalent) on hand. They will use bearing grease, which isn't up to the task.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 12 (permalink) Old 03-31-2011, 09:57 PM Thread Starter
Other than online where would I find this?
post #7 of 12 (permalink) Old 03-31-2011, 10:01 PM Thread Starter
Also I found a site where they sell it in tubes... Do I need something like a grease gun? Is there a connector or nipple or whatever you might call it like where you hook up a grease gun to grease something?
post #8 of 12 (permalink) Old 03-31-2011, 10:53 PM
clock152's Avatar
nope.. all you need is a finger.. as far as the voltmeter goes.. you can get a good hand held one at walmart.
clock152 is offline
post #9 of 12 (permalink) Old 04-01-2011, 07:27 AM
On the voltmeter, I don't know if what I did was as good as y'all describe, but I put a cigarette lighter plug on my bike so I could charge up my GPS, cell phone, or whatever and picked up a voltmeter that plugged into the cigarette lighter socket at china-mart for +/-$16.... It wasn't a constant monitor, just something to check the voltage when I wanted to.... I also put a lighter plug on my riding mower, and of course my car & PU have the lighter plug ins...
Just another thought thrown in, worked for me...lol...
post #10 of 12 (permalink) Old 04-01-2011, 10:17 AM
fergy's Avatar
You can usually pick up the 3 oz tube of Honda Moly 60 at a Honda shop, or buy it online. The links for threads showing how to do the spline lube and r/r relocation is in my sig.
X2 on the AGM battery!
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
