Weird Problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 32 (permalink) Old 03-23-2011, 07:20 PM Thread Starter
Weird Problem
My '92 VN750 has a strange problem with cutting out when I am cruising and holding the RPM's around 4-5000. It feels like it is starved for fuel. It wont die or drop RPM's much, just kind of sputters for a bit. Giving the bike a little choke helps it when it sputters, but doesn't fix it. Giving it a little throttle will usually help also.
I also noticed today that strong gusts of wind make the bike cut out really bad. If I hit a big gust of wind, the bike almost stalls out. I tried opening the throttle when it was stalling in the wind and it did nothing. It just about died when I gave it throttle.
So, I am pretty sure I have a carb/intake problem.
I read somewhere about modifying vent hoses, but I can't seem to find it now. I've had this problem ever since I've owned the bike. It's just now starting to get on my nerves bad enough to fix it.
My guess is that it is lean, but I dont know if it is the carbs or something else. Anyone else ever had this problem.
What do you guys think? Carb? Air intake? Something else? If you need more info, just ask.
P.S. Carbs are clean and I always run seafoam in my gas. I don't see any issues with the carb/air boots either.
nearma12 is offline
post #2 of 32 (permalink) Old 03-23-2011, 07:35 PM
there is a vent hose that runs from a tee at the carb vents that should run into a small opening that is just a holder for the hose,on the back side of the right air filter housing sounds like yours has fallen out or is gone.Check for about a half inch hose on the back of the filter housing if it is not plugged into that hole cut the end of the hose at about a 45 degree angle and push it back in there,if it is in there take it out and angle the end of it and trace it back to the tee at the carb and make sure it is attached and not kinked or has a hole worn in it.
post #3 of 32 (permalink) Old 03-23-2011, 07:50 PM
What Denny said, but it may be jammed in and stopped off, it is a vent so it should be ok if not plugged, so the 45* cut should work...
post #4 of 32 (permalink) Old 03-23-2011, 08:59 PM
What denny and OD said, If that don't work be sure to check that wasps have not nested in the hose.
post #5 of 32 (permalink) Old 03-23-2011, 10:31 PM
clock152's Avatar
yup yup!
clock152 is offline
post #6 of 32 (permalink) Old 03-23-2011, 10:49 PM
Couple of other thoughts, 1- if it happens to be a California bike it could be the pollution junk... 2- If it just does it after you run a bit it could be tank not venting and starving the carbs... You don't have to be in Cal. for it to be a Cal. bike, bought my 06 new in Tn. and it was a Cal. bike and gave me probs with the pollution junk...
post #7 of 32 (permalink) Old 03-23-2011, 10:57 PM
techdif's Avatar
Out of curiosity how do you know for if its a ca model? I am assuming that means California not Canada?
Look where your going not where you've been!
06 VN750
gutted mufflers
E3s
soft bags
windscreen
techdif is offline
post #8 of 32 (permalink) Old 03-23-2011, 10:58 PM
Yahoo VN750 Group Owner
Pick's Avatar
Send a message via Yahoo to Pick
What everybody else said. Since it is affected by strong winds, it is almost certainly that carb vent tube that is supposed to be stuck into the back of the right ear. I had this exact problem with my '86 after doing the ear shave and just leavin that hose hanging in the wind. Once I stuck it up under the tank so it was unaffected by wind, the problem disapppeared completely.
Jim "Pick" Foster
Dixon, IL
VROC #9492
2018 Suzuki Burgman 650
2010 Honda NT700V
http://www.flickr.com/photos/jimfost/sets/
http://s186.photobucket.com/albums/x294/jimfost/
Pick is offline
post #9 of 32 (permalink) Old 03-23-2011, 11:57 PM
that is exactly right ,I did a complete carb tear down on my300 4TRAX(since been stolen from me) before finding a mud daubers nest in the air intake almost completely blocking it off.But the happening at speed makes me think it is flopping in the breeze.I also forgot to tell him if it had been ear shaved to tie it up underneath the tank out of the wind,I put a lawn mower fuel filter in the end of mine and left one end open and zip tied it up underneath the tank. The filter lets it breathe and keeps the bugs out of the hose as well.
post #10 of 32 (permalink) Old 03-24-2011, 07:57 AM
Yes Cal. meaning California model... It will have 2-vent tubes coming from the rear of the tank, the one on the right side will go to the Cal. pollution control junk, the one on the left will be the normal tank vent and goes to the bottom of the bike and is open... There is also a page in the service manual (don't have my manual anymore) that shows the extra Cal. junk... HTH...
