Help!!!!!!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 03-20-2011, 09:54 PM Thread Starter
jrkgomez7's Avatar
Send a message via AIM to jrkgomez7
Unhappy Help!!!!!!!!!
Ok before you go making fun, I am a true newbie. so if I don't mention the correct name for a part don't laugh. I got a 1990 Vulcan 750. I always wanted a bike and this one came free from a client. I changed all the fluids - bought new air filters - bought carb boots. I had a fuel leak that was coming from the hoses on the carbs. fix that. removed mostly all the rust from various places. My current dilema is that now my fuel leak is coming from the left side of the air box. HOW AND WHY WOULD I BE GETTING GAS IN THE AIR BOX. Most important how do I make it stop.
He Died So We May Live
jrkgomez7 is offline
post #2 of 23 (permalink) Old 03-20-2011, 10:04 PM
1986vn750's Avatar
My dad's 1986 did the SAME thing. The problem turned out to be, the Fuel petcock was shot, so it was ON PRIME all the time! the weight of the fuel in the tank caused it to slowly seep from sitting. it leaked into the FRONT cylinder and past the rings, and into the crankcase. there was about 1.75 gallons of oil/gas mix in there. We rebuilt the fuel tap. changed the oil. fresh filter. Ran it. and no problems since. i gauentee this is your problem. has the bike been sitting before you aquired it? cuz his was sitting for atleast a year with a leaky fuel tap.
1986 Vn750
18,800 miles, and counting
Bone Stock
New cam chain tentioners
all fluids changed
Spline Lube
windshield
Engine Guard
B-stone S11 RWL-stock sizes
*wanted*
New grips
2001 Vn750
13,100 miles, and counting
spline lube
Bridgestone S11 100/90
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
1986vn750 is offline
post #3 of 23 (permalink) Old 03-20-2011, 10:05 PM
1986vn750's Avatar
And welcome to the forum!! Check in on the "newbie" forum. Tell us more aobut your bike! miles? mods? condition? Goodluck! hope i helped!
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #4 of 23 (permalink) Old 03-20-2011, 10:13 PM
Headbanger/Popes of Hell
ruger's Avatar
welcome to the madness! don't worry, nobody is going to laugh at you (only with you!). we have nothing but the best people on here that are willing to help you out with you bike or anything!
ruger is online now
post #5 of 23 (permalink) Old 03-20-2011, 10:17 PM
scuba's Avatar
I agree it's the petcock
www.vulcanriders.us scuba
vn750.com scuba
vulcanforum.com scuba54220
vroc.org VROC # 32658 (scuba)
1984 kz750 ltd
1982 yamaha maxim 750
2002 nomad trike
1978 suzuki 250
1964 harley amf
1987 yamaha venture 1300
1984 honda silverwing
custom exhaust
custom mirrors
custom grips
custom floorboards
ride-on tire sealant
corbin seat and backrest
custom exhaust
willie & max saddle bags
scuba is offline
post #6 of 23 (permalink) Old 03-20-2011, 10:23 PM
1986vn750's Avatar
I'd start there man. Order the rebuild kit. Have it done in no time. and you should be on your way. However. make sure no gas gets into your crankcase. that could be VERYYYYY bad if it did and u didnt know. luckily we caught it before we road it.
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #7 of 23 (permalink) Old 03-20-2011, 10:58 PM
Patriot Guard Rider
The DEUCE's Avatar
x2
VN750 #9300 & VROC #33453
The DEUCE is offline
post #8 of 23 (permalink) Old 03-20-2011, 11:20 PM
Probably is the petcock, but the prime position is only found on the earliest 3 or 4 models from 1985 to `87 or `88.
Your `90 petcock does NOT have a prime position, but could still leak if the diaphram is broke. A rebuild kit will probably fix it.
Check the inside of the tank for rust or any other crud inside while you are working on it, and clean if needed.
post #9 of 23 (permalink) Old 03-20-2011, 11:27 PM
1986vn750's Avatar
I was wondering that also, my 2001 has off, on, and res. i dont like this. because i drained my bowls to check for rust or any junk. and it was a pain getting it to restart cuz i couldnt prime it!
1986 Vn750
Bone Stock
all fluids changed
Spline Lube
windshield
Engine Guard
*wanted*
New grips
2001 Vn750
spline lube
Shinko 170/80
rear end oil change
aftermarket mirrors
windshield
otherwise all stock
*anticipated mods*
Engine Guard
post #10 of 23 (permalink) Old 03-20-2011, 11:45 PM Thread Starter
jrkgomez7's Avatar
Yes the bike has been sitting for some time (not sure how long), thanks for the reply will check it out tomorrow and post back with results
