New Serious Problem Broke Key-Key Code Location - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 16 (permalink) Old 03-10-2011, 04:04 AM Thread Starter
Into the Darkness
NetMatrix's Avatar
The key for my bike broke in the fuel tank cap. I'm needing to get a new key for it, but the key was not the original. Where would I hopefully try to find the key code at for the bike so I can get a new key for it? I'm not really wanting to spend the money for a new ignition and all the other keyed locks on the bike. That will get expensive really quickly.
English Version
ACCT to MCCT conversion video
https://www.vn750.com/forum/showthread.php?t=18235
ACCT to MCCT Conversion Thread created by wib714
https://www.vn750.com/forum/showthread.php?t=17917
Proximity Construction
NetMatrix is offline
post #2 of 16 (permalink) Old 03-10-2011, 05:32 AM
Redneck on a rice burner
Wileysden's Avatar
Location: American by birth,Southern by the grace of God ..,.AMEN !
Take you helmet lock off the back to a locksmith.He can make you another key.
Wileysden is offline
post #3 of 16 (permalink) Old 03-10-2011, 07:56 AM
Concert connoisseur
wib714's Avatar
of course you will have to unlock your helmet lock more than likely to get it off! in my signature is a write up on rekeying it but also detailed info on how to pick it. it is pretty easy!
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 16 (permalink) Old 03-10-2011, 12:29 PM Thread Starter
Into the Darkness
NetMatrix's Avatar
One of the helmet locks I didn't put back on the bike yet cause I lost the screw that holds it in place. Easy to find the key code that way. Thank you for telling me where the key code is located at. Now to get a new key ordered for the bike.
English Version
post #5 of 16 (permalink) Old 03-10-2011, 03:49 PM
flitecontrol's Avatar
A good locksmith should be able to make a key cheaper than the stealership. Keep the new "original" key in a safe place and carry copies made from it.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 16 (permalink) Old 03-10-2011, 05:58 PM
The actual "key code" was given to the original owner at the dealership. Some folks write the number down in their owners manual...but most are lost forever when bikes change hands. The code is not written anywhere on the bike that I know of.
But as mentioned, you can take the lock to a locksmith and he can make a key. I am however wondering if the helmet lock uses as many pins as the ignition switch. The switch uses 4 pins to identifiy the key...if the helmet lock uses only three of them...you might not be able to use the key in the ignition. (But I don't remember if the helmet lock uses 3 or 4)
Let us know if it works out.
post #7 of 16 (permalink) Old 03-10-2011, 06:23 PM Thread Starter
Into the Darkness
NetMatrix's Avatar
I'm having the locksmith make me a key for it. I looked at the ignition switch, and the key code is on there as well. It's also on the fuel cap. Well we shall see how many problems the locksmith has. I'll let ya'll know.
English Version
post #8 of 16 (permalink) Old 03-10-2011, 08:00 PM
Makes me think I might need to get an extra Ign. key and carry on the bike, just to be safe... I don't have a helmet lock, I just use a bicycle locking (combination) cable and go around the front spokes and thru the "D" ring on the helmet hanging on my Hwy. peg, the very few times I think I might need to...
post #9 of 16 (permalink) Old 03-10-2011, 11:27 PM
Concert connoisseur
wib714's Avatar
4 pins on the helmet lock when I rekeyed mine if I remember correctly!
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #10 of 16 (permalink) Old 03-10-2011, 11:55 PM Thread Starter
Into the Darkness
NetMatrix's Avatar
On the ignition switch itself it has the key code, but it's harder than heck to read it. It's gotta be clean, and looked at int he right angle, and light.
I'm having two keys made for my bike. The Locksmith said he's going to charge me about $35 to remove the broke key and make me 2 keys. Now it will cost a bit more than that if he has to tear the ignition switch apart to get the broken key out. So we shall see what happens with this task. He said he's seen worse though.
English Version
