What material is it build of? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-08-2011, 01:26 PM Thread Starter
What material is the crankcase, crankshaft, cylindrical piston, piston rings and the cylinder barrel build by?
Kawasaki vn 700 vulcan 1985
stormyinc is offline
post #2 of 7 (permalink) Old 03-08-2011, 03:40 PM
flitecontrol's Avatar
I believe everything you mentioned, with the exception of the crankcase, are steel. The case is aluminum alloy.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 7 (permalink) Old 03-08-2011, 06:18 PM
Aren't the pistons themselves aluminum?
post #4 of 7 (permalink) Old 03-08-2011, 06:50 PM
That is a yes on the pistons, cast aluminum,connecting rods and piston wrist pin are steel also.
post #5 of 7 (permalink) Old 03-09-2011, 02:56 AM Thread Starter
So the crankcase and the piston rings are made by aluminum and the rest i asked for is made by steel?
post #6 of 7 (permalink) Old 03-09-2011, 07:13 AM
not the rings but tr piston itself.the rings are steel.
post #7 of 7 (permalink) Old 03-09-2011, 02:49 PM
The crankcase, piston, and the exterior of the cylinder "barrel" (also known as a jug or block) are made of aluminum alloy. There is a liner made of steel that is pressed into the cylinder "barrel", that the piston rings contact.
As mentioned previously, the crankshaft, piston connecting rods, piston rings and piston wrist pins are made of steel too.
