Help me troubleshoot? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 02-11-2011, 05:48 PM Thread Starter
Ceal's Avatar
Today my bike started doing something... when I press the start button it kinda starts cranking and stops, then cranks again and starts.
The first crank is really short, then a stop, then cranks and starts.
At first, when it stops, it's kinda like when you have a discharged battery, but when it resumes it comes on strong.
You guys think it's electrical, or could it be mechanical? Like... something in there getting stuck on the moving parts.
When I changed the oil, I didn't check for plastic bits... I red that I should check for plastic bits after I was done with the oil change :-/ so that's why I can't tell for sure if it could be mechanical.
Ceal is offline
post #2 of 6 (permalink) Old 02-12-2011, 01:28 AM
first clean the start button... if that doesn't work, replace the starter relay, and if that still doesn't work, take the starter apart and clean the brushes
post #3 of 6 (permalink) Old 02-12-2011, 05:01 AM
^ Also check & clean battery connections, both ends especially the ground...
post #4 of 6 (permalink) Old 02-12-2011, 04:20 PM Thread Starter
Ceal's Avatar
Well, I already cleaned the start button when I changed the wiring... it was quite rusty, so I sanded it a bit to get rid of that... I got the contacts nice and shiny and it worked great after that.
I did clean the connections but only where they attach to the battery... I'll check the other end too, thanks for the advice!
I don't have a spare relay and the Mexican government just took away all the money I had to spend on the bike (license plates and driver's license were stupidly expensive), so I'll try bypassing the starter relay and see if it cranks better.
If it all fails, I'll take off the starter and look at the brushes.
Thanks a lot for the advice guys... I really hope it's not the battery or anything mechanical :-/
Ceal is offline
post #5 of 6 (permalink) Old 02-12-2011, 07:25 PM
wvshaneb's Avatar
Mine started doing that a few weeks before my old battery went dead. It also does it when it's really cold and the battery is weak. When the battery gets to charge a bit it doesn't do it any more. I've also read on here to take the starter apart and clean it up helps some with starting issues. I have 2 vn750's in the garage now. The starter on the newer one sounds different than the older one and starts much easier than the older one too. So there may be something to that starter cleaning idea.
Mom, I'm not wearing my helmet only for the purpose of taking this picture and
the background was digitally blurred to make it look like I'm going really fast.
wvshaneb is offline
post #6 of 6 (permalink) Old 02-12-2011, 09:57 PM Thread Starter
Ceal's Avatar
Cool, thanks for the reply... I really hope it's not the battery, but it just might be... if it is, I'll go for the Deka or Yuasa this time instead of the Wal Mart brand. They only gave me 3 months warranty :-/
Ceal is offline
