vn750 compatible replacement RR? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 02-11-2011, 04:20 PM Thread Starter
Hobocop
Cool vn750 compatible replacement RR?
Hi All.....does anybody know if there is a compatable RR replacement for the KawaVZ750 aka VulcanVN750. If so please respond as I am trying to source one in deepest darkest africa. There are other bike spares here but not for the VN750 (regarded as "grey import here")
Read this, comment please[/B], was seen on E-bay..figured I can get at least one of the RR for my KawaVZ750/Vulcan VN750
the EBay add reads:"the key word here is "FITS"
NEW OEM KAWASAKI REGULATOR RECTIFIER # 21066-1101
FIT'S
ZL600 ZL 600 A1-A2 ELIMINATOR 1986-1987
ZX600 ZX 600 A1-A3 NINJA 600R 1985-1987
KZ550 KZ 550 D1 GPZ 1981
ZX600 ZX 600 B1 NINJA 600RX 1987
ZX600 ZX 600 C1-C6 NINJA 600R 1999-1993
ZX600 ZX 600 D1 NINJA ZX-6 1990
VN700 VN700 A1 VULCAN 1985
ZN700 ZN 700 A1-A2 LTD 1984-1985
VN750 VN[/B] 750 A2-A9 VULCAN 1986-1993
ZR750 ZR 750 C1-C3 1991-1993
ZN1100 ZN 1100 B1-B2 LTD 1984-1985
VN1500 VN 1500 A1-A5 VULCAN 88 1987-1991
thanks
Allan is offline
post #2 of 5 (permalink) Old 02-11-2011, 05:42 PM
Ceal's Avatar
I used one from a Ninja 500 (EX500)... it's working. You might have to change the plug on it to match the VN750's wiring harness plug though.
Ceal is offline
post #3 of 5 (permalink) Old 02-11-2011, 11:31 PM
MANIC MECHANIC
vulcanjoe's Avatar
mine is from a 2006 yamaha r1 check out www.roadstercycle.com
34k so far
VN750.com member #613
Keep the shiny side up
coastered
de-goat and baffles removed
jetted 42-150 2 shims
Earshaved with unifilters
inside of tank coated
spline lube
Shindengen FH012AA r/r
TPE stator
Saddlemen saddlebags
2001 HD fatboy solo seat
Fergy's coil relay mod
vulcanjoe is offline
post #4 of 5 (permalink) Old 02-12-2011, 03:11 AM
Young Gun
kc_matt's Avatar
I followed in vulcanjoe's footsteps on this one! www.roadstercycle.com
1990 VN 750
First (hopefully last) time in the shop:
Carb rebuild New brakes front and back New radiator fan
I've done:
Spline Lube New (used - non-leaky) Gas Tank New Fork Seals New Pirelli tires New Yuasa Maintenance Free Battery
Fresh Dexcool coolant Upgraded Shunt-type R/R (Relocated) Headlight Bypass Stator tested - PASSED
Clutch Swap - EBC Street Racer Frictions with new eBayed steels ACCT to MCCT conversion
kc_matt is offline
post #5 of 5 (permalink) Old 02-12-2011, 12:00 PM
ARAtai's Avatar
Send a message via Yahoo to ARAtai
I have a VN800 R/R on mine and works fine. I don't recommend going for smaller bikes' R/Rs. Cause in the future you'll face trouble with regulation of the output voltage from your stator.
If you ride like there is no tomorrow, there won't be one!!!
Rebuilt Engine, Carbs & Starter Motor
M/F Battery
VN800 R/R (Relocated)
Head Light On/Off Switch
F&S Engine Guard & Luggage Rack
Givi Windshield
Givi E51 Hard Saddle Bags
Relocated Rear Signal Lights
Kuryakyn Grips
Custom Spot Lights
Custom Tank Bra
Custom GPS Stand
To be Added Soon:
12V Cigarette Lighter Output
Wish List:
Iridium Plugs
LED Brake Light
ARAtai is offline
