ratchet straps for hauling my bike to NC - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 12-30-2010, 03:21 PM Thread Starter
Wareagle1970
carolesteven's Avatar
Would these be sufficient, or do you recommend any others from either Sears or any other site?
http://www.sears.com/shc/s/p_10153_1...ckType=G4#desc
I appreciate all input and help!
Steven
2003 VN750 de-goated
Kuryakyn ISO Grips
Kuryakyn LED Voltmeter
coastered
Slipstreamer Hellfire windshield
Shindengen Mosfet R/R
Kawasaki Engine Guard
Fire & Steel Footpegs
Need Knifemaker to make me a seat like his
Hickory, NC
carolesteven is offline
post #2 of 13 (permalink) Old 12-30-2010, 03:30 PM
flitecontrol's Avatar
That should do it. Tying down the free end of the strap will help keep it from fraying.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 13 (permalink) Old 12-30-2010, 03:37 PM Thread Starter
Wareagle1970
Only thing that bothered me is it doesn't list the strap strength. Also, am trying to figure where to tie it down to my 1970 F100 pickup, that I will be hauling my bike in...
Kuryakyn ISO Grips
coastered
Hickory, NC
post #4 of 13 (permalink) Old 12-30-2010, 04:47 PM
I got a simular set at Wal-Mart for around the same price, but one end had web loops to go around your handlebars ... You don't want to use the hooks.
They do sell "soft straps" seperately, but if you look you should be able to find the set with them built in.
Four straps should be able to hold down a fairly large bike, does not make much sence to know how many pounds they handle when you really have no idea about how much force they need to cover anyway... If they say they are for motorcycles or ATV's you should be fiine as long as you are not off roading your trailer at 70 mph.
Do not cover the bike, and do as flite suggested and tape down the loose ends....not only so they do not fray, but ,mostly so they do not beat the paint right off your bike.
They do make tie down hooks you can bolt to truck beds, I would suggest getting some.
Make sure you do not crank the front forks all the way down... leave a bit of fork travel so the bike can absorb shocks. The top of the rear shock mount is the best place for the rear straps.
post #5 of 13 (permalink) Old 12-30-2010, 06:44 PM
I've hauled dirtbikes a lot more than the Vulcan, but same principle.
I found it best, when hauling in a pick-up, to have the bikes front wheel in one front corner of the bed, and the rear at the opposite rear corner.
That keeps the front tire from possibly sliding out to one side or the other if it's in the middle and there's no wheel chock.
When tying it down, if the front tire is in the front passenger corner, run the left strap to the front drivers side of the bed and then the right strap to the middle or rear or the passenger side of the bed.
With the front straps as wide as possible, where they attach to the bed, you need very little downward pressure to hold the bike very secure.
One strap on the left rear of the bike to the middle or front drivers side of the bed will hold the rear of the bike fine.
I wouldn't use those bed tiedowns that mount in the stake pockets of a bed. Too much of a chance of them pulling out.
DON'T put the kickstand down once you are underway!!
After the first 20-40 miles or so, stop and check that the straps are still holding securely.
post #6 of 13 (permalink) Old 12-31-2010, 04:10 AM
gun slinger
centurynick's Avatar
i ran my tire up the the front of the bed then took a tie down from each fork and load the front suspension a little (forward), then i ran one through the rear wheel and ratched it tight (towards the bed) , i then shook the crap out of the bike and if it didnt move i rolled on down the hwy
i bought a 6 pack of ratchet straps from home depot for like $9.00
i have used them for moveing 15 different bikes and a bunch of other stuff i wouldnt want to fall off on the hwy
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
post #7 of 13 (permalink) Old 12-31-2010, 02:14 PM
I have never trucked a bike, but just recently read a suggestion for making an inexpensive front wheel chock for a pick-up truck. Cut a piece of plywood to fit the width across the front of the box and screw a couple of pieces of 2"X4" vertically to it to center the front tire between.
When you do put some tie down points on the bed of the truck, make sure they are anchored solidly with bolts to the frame, or to large reinforcment plates under the sheet metal floor. Just using flat washers under there would be asking for trouble.
post #8 of 13 (permalink) Old 12-31-2010, 05:11 PM Thread Starter
Wareagle1970
pack of 6 ratchet straps for $9? You happen to know their strength?
Kuryakyn ISO Grips
coastered
Hickory, NC
post #9 of 13 (permalink) Old 01-01-2011, 04:15 PM
gun slinger
There 12' 440 lbs working load and 1320lbs break capacity and it a 4 pack
2010' voyager
lots of hand guns
post #10 of 13 (permalink) Old 01-02-2011, 11:14 PM
Daily rider
ksmnet's Avatar
The first time I hauled my VN750 was a couple of years ago when I bought my used Chevy S-10. I rode the bike to the dealership, and after making the deal on the pickup, asked for help loading the bike into the bed. All I had to tie it down was a container of bungee cords. Hauled the bike about 80 miles home. It didn't move a lick. Hooked the bungees to the tie-down hooks that came factory in the box. They're just below the top of the box in each corner.
2017 Indian Roadmaster (current ride)
2003 VN1600A (Traded August 2017 to #1 son for a Bushmaster AR)
2001 VN750 bought 4/19/08 w/2309 miles(Sold April 2010 with just over 12,000 miles)
VROC #33035
__________________________________________________ ________________
Just when I thought I was winning the rat race, somebody moved the finish line!
ksmnet is offline
