spark plug socket - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 12-21-2010, 01:57 AM Thread Starter
lippy's Avatar
spark plug socket
hi i am trying to change my spark plugs but i find with the plugs that are down in the motor i cant get my socket or any other socket onto the spark plug to undo i know it is a 18 mm socket but there is not much room to move around the spark plug to get the socket over is there a special socket for this job or am i missing something bike is a 86 vn 750
bike
1986 vn 750
lippy is offline
post #2 of 12 (permalink) Old 12-21-2010, 03:24 AM Thread Starter
lippy's Avatar
dont worry sorted a 18 mm tube spanner works a treat and only 3 bucks woohoo
bike
1986 vn 750
lippy is offline
post #3 of 12 (permalink) Old 12-21-2010, 05:45 AM
Sears Craftsman 18mm deep well socket # 44435
post #4 of 12 (permalink) Old 12-21-2010, 05:49 AM Thread Starter
lippy's Avatar
the only problem with that is we cant get that item here in australia
bike
1986 vn 750
lippy is offline
post #5 of 12 (permalink) Old 12-21-2010, 06:39 AM
OK, then the only thing I can say is, my Sears 18mm DW socket # 44435 has an OD of .930" or 23.62mm and worked fine...HTH...
I think as long as it is a thin wall deep well 18mm it will work...
post #6 of 12 (permalink) Old 12-21-2010, 06:45 AM Thread Starter
lippy's Avatar
cool i went a bought a tibe spanner like the ones they sell for lawn mowers and it worked a treat fits down and removed spark plugs job done
bike
1986 vn 750
lippy is offline
post #7 of 12 (permalink) Old 12-21-2010, 10:12 AM
flitecontrol's Avatar
The plug socket with the original tool kit works too, but that must be missing on your bike.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #8 of 12 (permalink) Old 12-21-2010, 10:39 AM
I took the grinder to my socket and ground it down to size.
post #9 of 12 (permalink) Old 12-21-2010, 12:33 PM
n2omike's Avatar
Any fairly thin walled 3/8" drive 18mm deep well should work just fine.
Higher quality sockets usually have thinner walls, as they are generally made out of better metal, and can be made that way to reach into tighter spots.
Good Luck!
05 VN750
Iridium Plugs
Spline Lubed front/rear
ignition pickups gapped
AGM Battery
Relocated MOSFET R/R
Coaster Mod
Pilot Screws at 2-1/4 turns
Slipstreamer S-08 Windshield
F&S Saddlebags/Mounts
Luggage Rack
12V Outlet
Mustang Seat
sissy bar
Oversized Pirelli Front Tire
6k miles
PW50, XR50, TTR90, XR100, DT175 (2-smoker), CRF230F, XR250R (dual sported), XR400R 4 KIDS, LOL!
1966 mustang street/strip
4-speed, nitrous
[email protected] 135.6
n2omike is offline
post #10 of 12 (permalink) Old 12-21-2010, 12:39 PM
I just went through the same thing. The problem is that most deep sockets are too thick to fit in the narrow space. I ended up buying a socket at the stealership for $18 but you could probably also buy a cheepy (say Harbor Freight) and grind it down.
BTW: I usually also grind the ends of my sockets down as well for good measure. For reasons that totally escape me, if you look carefully at most sockets you'll see that the ends are rounded off resulting in less contact with the bolt (not an issue for the plugs but in general). If you grind those rounded sections down you get more surface contact with the bolt.
-Robert
RobertGary1 is offline
